Twin Turbo LS Boat Engine
Looking at the back (flywheel end) of the engine, there is a plug in the block, bottom left. Top right if the engine is upside down. Behind that plug is the dumbbell. That oil galley is drilled the entire length of the engine and the dumbbell is a divider of sorts, blocking the passage where the oil filter taps into the galley. Without the dumbbell, oil would not flow through the oil filter and just go straight through and up to the main galley and on to all the bearings and lifters..
If you're going to attempt using the block you have, definitely pull those plugs, remove the dumbbell, clean out that passage, and put a new bumbbell in.
What oil are you using? Filter?
I'm certainly not steering you away from one. Fitting one will pretty much guarantee a good solid oil supply....but as yet you dont really know for sure if you did not have that.
As Seth said, you really need to log oil pressure and I'd go one further and say to use a proper ecu that can offer a safety trip if oil pressure misbehaves even the slightest bit.
That way you can protect the engine, but also get a picture of what's going on in order to resolve it.
TBH even if you go dry sump....I'd be saying to do the same, as you can also get protection against the belt failing on the dry sump setup.
At the minute you've had problems, but just do not know what the actual cause was, or when etc. It just makes it so much harder to fix.
If these are repeatedly tripped, then yes you'll need to figure out why.
An oil pressure sensor is cheap.
Presumably in a boat you have plenty of room for a good oil pan design, both that can "scavenge" to some degree, and with plenty of capacity. So oil supply should never be an issue regardless of pump used ?
Trying to restrict oil to turbos was never going to end well, but yes if you believe that is an issue, BB turbos would require much less oil. BB turbos would almost certainly need cooling water too for such an application too.
And when the oil pump has enough capacity at say 2000rpm...at 5k, a lot is or should be getting bypassed at the relief anyway.
But monitoring oil pressure and temperature would be a simple first start. Although presumably temps are easily kept in check ?
The oil pan mods may well have already solved any issues you were having, you just created the turbo death by starving them of oil.
I agree 100% never restrict a journal turbo. Thats not your issue. The high volume pump likely is and it's very common to "pump the pan dry" with aftermarket pumps. Or even high volume factory pumps (DOD style). The fact that the boat is "nose up somewhat compared to a car compounds the problem. I'd put a standard oil pump on it. Not a high volume for starters. The turbos aren't "sucking the system dry". You can also improve the drains in the heads back to the block. Kurt Urban is a big name in the LS world. He ran oil restricting push rods in his turbo shop truck for over 100k I believe. The factory tends to over-oil the top end a bit. An accumulator is great for a drag car but when a boat gets up on a plane or is nose up the entire time its racing oil is all going the the rear of the pan. A good pan and overfilling the system are the easiest ways fight this IMO. Sounds like your on your way.
If there is space, it should be easy to make a very deep pan, with good windage, and keeping the oil mass nowhere near the crank, and also well contained and protected against surge/movement. Allowing a huge amount of oil if need be, but never a "high" level as with a normal car type setup where ground clearance would always be an issue.
Obviously a dry sump is another option, but I can't see it being necessary at all.
Although some rear mount people run a standalone oil system for their turbos using an electric pump. Which is simple. I guess at a stretch that would be an option...but the turbos are not starving your engine of oil.
