Crankcase to Exhaust Question
Old Feb 23, 2016 | 12:32 AM
Blown06's Avatar
8 Second Truck Club
Originally Posted by Hi-Po
Is there a certain amount of exhaust length you should have, after the weld on tubes? I am running the TSP true dual system, dumped before axle.
This type of set up does not work with mufflers
Old Feb 23, 2016 | 07:07 AM
Ping King's Avatar
I run a crankcase evac through a full exhaust, but it should be noted that the exhaust is 3.5" with a straight through hooker muffler.
My setup consists of two catch cans, some check valves, and the pan evac setup. Driving around normal, it will act like a standard PCV setup. When i'm into boost, it closes the check valves and pulls through the exhaust.
Old Feb 29, 2016 | 05:47 PM
kingtal0n's Avatar
I like this. Any pics? I would love to see how you fit all the lines together, routed them, etc
