Ethanol Content and actual results
Old Feb 16, 2016 | 04:28 PM
oscs's Avatar
Default Ethanol Content and actual results
I am constantly reading about people going above an beyond to measure ethanol content. There are guys losing their **** with 73% results vs 85% or 90%. Does anyone have any actual data or instances were there has been a failure or drastic change in results from 70-85% content? I think the vast majority of people running E85 are misinformed about what its actually capable of..
I know people running the same timing on E60 as they are on E85.. Just seem to me that people are getting worked up over nothing.. Discuss.
Old Feb 16, 2016 | 04:40 PM
GMCtrk's Avatar
If you're tuned for E85, any lower E content will result in rich mixture at WOT.
I've run 1 part 93 to 1 part E85 (E48) with no difference compared to straight E85. Stock 02 6.0, 10.6:1 comp.
There's some scientific article floating around showing that E50 has the same knock resistance as E85.
Old Feb 16, 2016 | 04:41 PM
3 window's Avatar
Google Delphi study on e50 vs e85 fuel. ZBrown was kind enough to send it to me on YB. Its easy to find and the results are exactly what you say. Same detonation resistance with e50 vs e85. Injector duty cycle will be down using 50-60 vs 85 along with stringing out your pump(s) a bit more. So that's a plus. I plan on mixing my own e50/60. The only difference I've heard is the smell.
Old Feb 16, 2016 | 04:46 PM
oscs's Avatar
I always forget about that guys are still using HPT or non adjusting management systems, So i can see the need for need for the flex fuel sensors. I've read the article, I probably should linked it. I think a lot more people should pay attention to the differences between 50/85. It might free up the need for such a drastic fuel system and ease some minds.
Old Feb 16, 2016 | 04:47 PM
oscs's Avatar
That's correct.
Old Feb 16, 2016 | 04:55 PM
3 window's Avatar
A little info, http://www.nav200.delphi.com/pdf/techpapers/2010-01-0619.pdf
Old Feb 16, 2016 | 04:58 PM
GMCtrk's Avatar
I only run straight E85 now, but when I did mix I would just adjust the fueling in my tune. Takes all of a couple minutes. There's no good way to use an ethanol sensor on an 02 operating system with EFI live COS tune.
All being said, I do prefer the piece of mind with the full e85, on a stock motor.
Old Feb 16, 2016 | 05:07 PM
Forcefed86's Avatar
I get that the antiknock index of E50 may be almost the same as E85. I wonder if the cylinder cooling effect of higher alcohol percentages also play a big roll.
I mean methanol and ethanol have basically the same octane. But the ratio of fuel to air is so much higher with methanol that it's proven to be a superior fuel. Does the same apply to an E50 blend VS say e85 or e98 etc... Higher percentage of alky in the fuel the more fuel you'll have in the CC cooling things down.
Old Feb 16, 2016 | 05:15 PM
oscs's Avatar
That's a good point. I always thought it had to do with the shear volume of fuel in the cylinders providing the additional cooling.
Old Feb 16, 2016 | 08:03 PM
boostedrides's Avatar
I never hear much about e87, is that better than e85?, we just got a new quick trip near me that has it, was thinking that I may switch over to it for my turbo 5.3.
Old Feb 16, 2016 | 09:25 PM
dburt86's Avatar
does anyone have an idea of the percentage difference of duty cycle you would have between e50 to e85?
Old Feb 16, 2016 | 11:42 PM
oscs's Avatar
Massive. E50 is roughly 15% more fuel than 93 where E85 is closer to 30%
Old Feb 17, 2016 | 12:51 AM
SPRAYED 01's Avatar
I really dont understand why there isn't much difference in anti knock and octane between e50 and e85. Where is the cut off? Would E40 vs E85 be a huge difference. Or E10 (regular pump gas) and E30 be close?
Old Feb 17, 2016 | 06:57 AM
Forcefed86's Avatar
Makes sense to me. I'm guessing the lesser octane fuel that is blended doesn't magically disappear when you add ethanol. It is still going to burn much faster and light off the ethanol in the process.
With E85 your base fuel is sometimes 85 octane or lower. That base fuel is going to light off much earlier than the ethanol. Ethanol can only do so much to slow the burn down when there is a lower octane in the mix. That's why mixing a low and high octane fuel isn't the best idea.
Better to use as high of a base octane as possible. If I were mixing E50 its easiest to grab 2 empty 55 gal drums. Fill one with a known good 85% ethanol (or higher) source and the other with the highest octane ethanol free fuel you have(91-93 etc). Then mix them yourself prior to filling your tank. 2 drums should last you all year.
5 gal of E85 and 3 gal of premium will give you 53% ethanol by volume and have the higher octane base fuel.
You could also mix a barrel at a time.
35 gal e85
20 gal reg = 54.1% ethanol
But I'd be worried the fuel would separate sitting in the drums for extended periods? (possibly not? No idea).
Old Feb 17, 2016 | 08:08 AM
rotary1307cc's Avatar
E50 Ttt is all I know
I see around a 17% increase in fuel demand from gasoline to e50.
E85 is easily 30%+
I've ran it for years now and will continue to do so
Get all the advantages of e85 without the disadvantages that come with it
Says directly in that study that the antiknock characteristics of the fuel are not directly proportional to the ethanol content
Old Feb 17, 2016 | 08:18 AM
If they would of ran and collected data on the upper 13.x CR combo we would of really learned something
Old Feb 17, 2016 | 10:00 AM
hellbents10's Avatar
LS1Tech Sponsor
Power increases from 50% to 85% will come from the extra oxygen carried in with the ethanol and burned. After 87% these gains stop as you need some gasoline to get the mix going properly. I think with forced induction there may be some advantage to the shear amount if fuel you can light up for the cooling properties.
Old Feb 17, 2016 | 11:10 AM
Detoxx03's Avatar
Mine adds anywhere form 1-3* depending on ethanol %.
Old Feb 17, 2016 | 11:29 AM
RonSSNova's Avatar
I'm very interested in doing this.
It will allow me to get away from being on the edge fuel system wise.
And putting real fuel in will eliminate the goo.
I finally got a 55 gal barrel. We have both E85 and 92 Oct ethanol free fuel available. Of course not at the same station....
Is there a list of stoich values for the various blends?
Old Feb 17, 2016 | 11:37 AM
Forcefed86's Avatar
Look at chart on post #8 above. 11.57 for E50.
I'm at 40ish percent ethanol now. Was trying to purge the fuel system for winter storage. Pulled 20% fuel across the board. I can barely idle the Racetronix low-Z 160's this way (MS3 AEM injector driver). Fumes are much worse in the cabin as well. Figure I'll stick to the E70 at the "bad" gas station. We get that year round here. Not driving out of my way for that extra 15% will be nice this year.
