Cheap 10 micron ethanol compatible fuel filters.
Old Feb 21, 2016 | 11:09 AM
Forcefed86's Avatar
Default Cheap 10 micron ethanol compatible fuel filters.
I've been running these filters for 5-6 years on my E85 setups. Pick them up at the Farm Supply stores here locally for about $12. They filter better than most expensive SS elements, flow a ton, and hold up great. I usually change them every year, but I was lazy and left this one in for 2 years. Split it yesterday. Looked great. The element felt a little dry and brittle maybe, but no more than they always do when I split them yearly.
Best filter out there for E85 IMO. They also had a new micro glass filter that claimed 2 micron filter capability.
I believe the filter housing is zinc? Not 100% on that but it seems to be holding up fine as well. I believe what looks like little corrosion marks are casting flaws. They never seem to get worse. And I don't see the white crusty corrosion common with ethanol.
Old Feb 21, 2016 | 12:58 PM
MY_2K_Z's Avatar
Where did you get the filter housing?
Old Feb 21, 2016 | 01:10 PM
35spline's Avatar
Specs on the Cen-tek 72010 are 50psi working pressure, what psi are you at?
Old Feb 21, 2016 | 01:20 PM
Forcefed86's Avatar
They sell the filter housing with the filter. Like so... The CIMTEK is newish. They use to sell goldenrod like below.
http://www.northerntool.com/shop/too...FQiJaQod9n0L8g
I run at 75psi plus on pressure. We even tried to blow one of these filters up with 120psi of shop air and it didn't even phase it. I've always run that much pressure on several cars now.
Old Feb 21, 2016 | 01:37 PM
35spline's Avatar
Is your housing aluminum? Would there be any issues with e85 if it were zinc die cast or ever cast iron?
Old Feb 21, 2016 | 01:49 PM
Forcefed86's Avatar
It's really light weight, it might be zinc plated alum, not sure. It's made to be compatible with ethanol as is most "farm" fuel equipment.
Old Feb 21, 2016 | 07:12 PM
1bdbrd's Avatar
Can these be mounted sideways? These seem to be kind big to hang under a car lol
Old Feb 21, 2016 | 07:30 PM
Forcefed86's Avatar
Yea I mounted mine sideways and upside down.
Old Feb 21, 2016 | 07:41 PM
NemeSS's Avatar
Good find
Old Feb 21, 2016 | 09:23 PM
RonSSNova's Avatar
I've used this style filter for years on my car before I went turbo.
Same alum base etc.
Mine is pre pump.
Ron
Old Nov 8, 2017 | 12:34 PM
JoeNova's Avatar
Restricted User
I've been fighting spin-on filter selection for a little while now, so I'm going to bring this back up.
I bought 2 Goldenrod filters for almost nothing but they didn't come with the mounting head, which is now $35 at Tractor Supply down the street.
I found these filters from GROZ. I'm going to buy them just for the filter head because they are so cheap.
https://www.ebay.com/itm/Fuel-Filter...pZGhI2&vxp=mtr
$16 shipped for filter/head.
The description says that it comes with the head. There are 55 sold with 100% positive feedback so it would seem as if the description isn't misleading. The filter is 10 micron nominal with 20 gpm flow, but unfortunately a 1 1/2" - 16 filter thread instead of the more common 1" - 12.
Also, what are you guys using for the 1" NPT threads on the filter heads?
I'm debating whether or not to run 2 filters, pre and post pump, or just one filter pre-pump.
Old Nov 8, 2017 | 12:58 PM
Forcefed86's Avatar
20$ shipped on amazon... for the 1" NPT 570-1 PN. Use a 1" NPT to AN8/AN10 etc from e-bay.
Amazon Amazon
The big 4303 and other rock crusher style pumps I'm not worried about a pre-filter. The smaller pumps I'd want a sock or something to filter the larger particles out. I haven't run a pre-filter on my 4303 for years. Aside from this bad boy... lol. I bought it to install under the fill lid of the fuel cell, but it was too small. It's a pre-filter for motorcycle gas tanks. Makes me laugh every time I use it! easier/cheaper than a filtered funnel.
Attached Thumbnails Cheap 10 micron ethanol compatible fuel filters.-cam00435_zpszvi8wna0.jpg
Old Nov 9, 2017 | 07:52 AM
JoeNova's Avatar
Restricted User
Finding 1" NPT to 8AN on ebay has turned out to be a challenge.
Old Nov 9, 2017 | 09:40 AM
Lawhead's Avatar
Yeah, Tried to find 1" NPT to -10AN is well
A unicorn
Old Nov 9, 2017 | 09:44 AM
JoeNova's Avatar
Restricted User
I can use an adapter to knock 1" NPT down to like 3/4" NPT and then use a 3/4" to 8AN or 10AN. That will likely be the route I go.
Old Nov 9, 2017 | 10:07 AM
Lawhead's Avatar
Link up the fittings when you find them bud all I'm finding is male to male stuff
Still looking for a filter set up for my AEM 380s
Old Nov 9, 2017 | 10:11 AM
Forcefed86's Avatar
I believe my actual head was 3/4. Grab a SS 1” to ¾ pipe fitting.
Or the $32 ¾ head w extra filter.
https://www.ebay.com/itm/Goldenrod-S...sAAOSwY~laAcZe
Old Nov 9, 2017 | 10:16 AM
Lawhead's Avatar
That right there looks like the ticket!
Wonder if I should do two one pre and post pump just obviously use something more along the lines of 100 microns to make sure it flows plenty
Old Nov 9, 2017 | 10:26 AM
Lawhead's Avatar
the 3/4 will be plenty for a -10AN what you have linked there is that just the filter or the whole set up? I'd assume people are mounting them with just putting a mounting clamp on either side of the hose right after the housing to hold it up there as it don't look like there is much in the way of being able to mount it
Old Nov 9, 2017 | 12:32 PM
Suncc49's Avatar
I ended up using filters from a speed shop in virginia called performance dynamics... worked out good... 100 micron and 10 micron pre/post aem 380 pump
