please help getting this boat out of the hole!
the car weighs a ton or should i say 4,700# so i realize that it will never be in the 1.5 sec 60' times but so far the best 60' time i have been able to get is 2.1 60' times and 11.99 time slip really hoping to get the car in the 10's .
the car is just a slug out of the hole for 15' then boost hits hard and i loose traction i can Not build any boost on foot brake.
what could i do different? heads,cam 2 step,boost controller?
Run a sloppy transbrake. It'll cost you 10 bucks and an hour of your time. Locks the trans in 3rd gear on the line so you can hold it back with the footbrake and build lots of boost. Releasing it forces it to downshift into 1st and launch. All you need is a relay and a toggle switch or momentary button to tap into the trans wiring.
Cheaper and easier than a conventional transbrake, no need to modify the trans. Cheaper than a 2 step as well, which still won't help you if your car won't be able to hold the tires under boost on the line without pushing through the brakes. My car builds 12-14 PSI on a 2 step and shoves right through the brakes. Thankfully, I also have a 4L80e. I just use the 2 step to control RPM, not to build boost.
We are putting together a somewhat similar set up other then a single on my buddy Dan's 4 door 69 Caprice on Ride Tech coilovers. I think you may have seen that. I know he's talked with you on facebook a few times. Hopefully we'll have his together soon and he's going to try some radials.
Like said above, look into a 2 step. Would help a lot. Then I would get a good tire on it.
So basically, sloppy trans brake, drag radials and 20 lbs of boost you should get your 10's!
lol. you will not get there with 122mph trap speed.lol pretty sure that will change with a better 60' times and more boost.!
my compression ratio is only about 9.5 to 1 so one would assume that bumping that up would wake it up on the low end as well.but that might be later.
The sloppy transbrake just forces it into third gear, using nothing but a relay and a switch. You use your brakes to hold the car still in 3rd gear. Releasing the switch downshifts into first. My car stalls to about 2600 and 2-4 PSI on a prepped surface before it pushes through my crappy brakes. In 3rd gear, it stalls to 4500 and 16 PSI on the street.
I would still get some real tires before I attempted the sloppy brake..
Looks like the Wallace Calculator thinks 122 mph could get you to a 10.99
If you're running vacuum assist brakes, consider swapping to hydroboost
And put some Mickeys on it. Those rubber bands are killing you
Added to this>>>suspension set up to xcross, etc, is not allowing the chassis to work. I'd bet a video would show virtually no pitch rotation.
