Ls1 Turbo top end setup questions
So after heads failure on my ls1 76 trans am i decided to go turbo.
Soo here is a little about my engine. Its an stock ls1 aluminium block with a set of high compression ported heads (took it off already). It has a big loop cam (i bought it with the cam so idk the specs), it was converted to carburetor setup with a high rise intake.
So would it be a problem to run turbos with big cams?
What heads specs would be preferred with turbo setups?
I am thinking of keeping the carb and go with Blow through carburetor for the turbo set up so would it be hard to tune it?
Thank you
Keep your chamber as small as possible. A stock pair of 317 heads will give you a c/r of 9.3, that's appropriate for a fair amount of boost. A pair of polished 241 heads will give you a c/r of around 9.8, good enough for an application with mild boost.
Keep in mind that using a big cam will lower your dynamic compression ratio and will cost power at lower rpm also.
Good luck!
I'm not too keep on the whole low compression idea. I was skeptical coming into my current build because I typically run 8.0:1 - 8.8:1 compression on turbo builds, so 10:1 was new to me. It works fine. I just tore it down for inspection and lifter replacement. Not a single sign of detonation even being driven at 20 PSI daily and hitting 30 PSI on pump gas on 2 occasions. That being said, 317s are cheap and easier to come by than the 799/243 heads, so why not. 317s certainly aren't the most common. There are far more 862 or 706 heads out there, since there are far more 4.8s and 5.3s than 6.0s.
