Considering Procharger, Do it or hold off?
Old Mar 23, 2016 | 07:05 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by Camarokid327
I was planning on just using the 6 rib so I can then use my stock balancer. Do you strongly suggest I switching to the 8rib on my p1?
The 6 rib kit uses a much smaller 6.0" crank pulley, which causes you to use a smaller blower pulley to make boost. Is your head unit a P-1SC or a P-1SC-1? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Mar 23, 2016 | 09:12 AM
Camarokid327's Avatar
It's a P-1SC.
Old Mar 23, 2016 | 09:38 AM
LS1Tech Sponsor
It's a P-1SC.
http://shop.brutespeed.com/ATI-DPxxx...-ATI-DPxxx.htm
With your engine combination you are going to need a 3.0" pulley for the six rib. Bob
__________________
Old Mar 23, 2016 | 10:40 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Hey, if you got it for a great price, then all the better. You will be extremely happy and satisfied with it.
Old Mar 23, 2016 | 10:49 AM
Rise of the Phoenix's Avatar
No kidding. If you paid right at $1,000 for it, I'd say you got a good deal. I still can't believe used P1SC Prochargers sell for $1,600+.
Old Mar 23, 2016 | 11:30 AM
Mike 02T/A's Avatar
Go 8 rib and be done!
I SHOULD have my 8 rib Procharger crank pulley and 60# SD injectors up for sale soon. I might try and see what this F1A will do a 74k rpm : )
I would skip on the 255 pump and go 340LPH or higher from the start.
Old Mar 23, 2016 | 04:26 PM
DavidBoren's Avatar
I second the notion to skip the 255 and go straight to a 340 or higher pump. Keeps you from having to deal with it again WHEN you want more power.
Old Mar 23, 2016 | 04:28 PM
Is the 340LPH pump a direct replacement, or does it require quite a bit of modifications to the stock bucket? Do you guys run just the 340LPH pump, or do you run it with the stock pump?
Old Mar 23, 2016 | 05:00 PM
Kmspeedie's Avatar
I know I will probably catch flack from some but I picked up a P1 head unit freshly rebuild with zero miles for a price I couldn't pass up (under 1k shipped) and would work for my budget and goal.
Few questions before I place an order with Bob and other purchases:
1. What size pulleys (crank/head unit) do I need to make 7-8 psi with my current setup?
2. Will a Racetronix 255 w/ hot wire kit and 60# injectors be fine? (planning on running a Snow Performance Stage 1 kit as well)
3. Big Red or black Proflo bypass valve on FMIC set up? Proflo valve work with truck hat/filter??
4. Has anyone been able to mount a FMIC and keep some of the foam bumper? Leaving some around the intercooler?
alky control...
Old Mar 23, 2016 | 05:02 PM
Thanks Bob! I will be giving you a call sometime next week to place an order for pulleys, j bracket, truck inlet/hat, bets, oils, and a few other misc parts!
Totally agree, which is why I jumped on it right away! I wouldn't pay $1300 + for just a P1SC head unit, if that was the case I would definitely go the D1 route.
I also just picked up the black Pro-Flow surge valve, spal 16" (straight blade) fan, and two piece Procharger shroud for $145.
I don't believe it is. I came across this thread that has some good info in it.
walbro 255 vs aeromotive 340 stealth
Parts needed to upgrade to a 340 pump:
(1) - Aftermarket fuel pressure regulator since the stock one in-tank won't be able to keep up.
(2) - Upgraded wiring harness with new bulkhead connector Racetronix posted above.
(3) - Need to run a -6an return line to the return port on the bucket and remove the stock regulator.
(4) - Need to either run a new -8AN feed line or you can use the stock line and find a fitting to cap off the port on the T junction where the lines split apart near the fuel filter and return line.
Old Mar 23, 2016 | 07:17 PM
LS1Tech Sponsor
Thumbs up
Sounds good, thanks! Bob
__________________
Old Mar 24, 2016 | 07:56 AM
  #32
conan's Avatar
You going to go with a front mount cooler or the Procharger twins ?
Old Mar 24, 2016 | 09:37 AM
  #33
I'm going with an ebay CXracing FMIC setup. Just debating on whether to go with a black intercooler or not. I think a black one would look badass (subtle and stealthy) behind my SLP SS grill when I trim it up.
Old Mar 24, 2016 | 10:08 AM
  #34
I think the black one will look nice too. I'm jealous of the deal you got on the Procharger.
Old Mar 24, 2016 | 10:24 AM
  #35
conan's Avatar
Nice, The front mount is so much cleaner looking and easier to deal with than the twins. I don't think the color will mater much with that grille, you wont be able to see much back there. I would also recommend getting a tube bumper support to hang the cooler from. I got my support from Burkhart chassis. Made the job nice and easy.
Old Mar 24, 2016 | 12:15 PM
  #36
I found it on one of the fbody craiglist facebook pages. He originally wanted $1200 but talked him down
I'm planning on cutting my bumper/grille like the image below... so you will definitely be able to see a good amount of the intercooler.
I'm planning to mount my intercooler the same way Alchemist did. I think I should have enough room as I don't believe the Camaro bumpers are as deep as the T/A's and their fog light holes. We'll see!
Has anyone been able to keep some of the impact foam around the top and sides of the intercooler? To keep a little support for the front bumper cover? I know a tubular frame support would be easier but just seeing if its been done before.
Old Mar 25, 2016 | 08:12 AM
  #37
conan's Avatar
Sorry your pic was too dark around the grille to see how much was cut out.
I have seen peoples pics of the cooler mounted in the middle of the bumper support and they left some of the foam on each side. I chose the tube support to keep the OEM foam and frame in one piece and not cut it all up.
Old Mar 27, 2016 | 10:40 AM
  #38
2BAD4U's Avatar
I've got my low mileage P1SC-1 listed up for sale right now for 1,600 as I just Bought a F1A from Bob aswell as a bunch of other goodies. But the P1sc-1 isn't no slouch. It's a noticeable improvement over standard P1SC. I put down over 625whp on 10lbs. Took inlet off and saw 14lbs. By my butt dyno was close to 700ish and I was spinning it 2k below max impeller speed.
Old Mar 27, 2016 | 04:15 PM
  #39
3 window's Avatar
I know the setups might be quite different, but some good information. http://www.yellowbullet.com/forum/showthread.php?t=1755330
Old Mar 27, 2016 | 05:32 PM
  #40
Rocks00Z28's Avatar
Is there a difference in performance from the twins to a front mount cooler? I have been thinking about a D1 myself.
