Budget build help needed
Old Mar 9, 2016 | 10:01 PM
Anthonyon44s's Avatar
Default Budget build help needed
Looking to put a single turbo kit on my 05 Silverado 5.3 possably a on3 kit debating on what injectors to use (60-80) and where to install o2s noticed most kits have a bung welded in the down pipe. The motor is bone stock for now will more than likely do a cam/intake swap next year. Any guys around flint MI that can do tuning?
Old Mar 10, 2016 | 08:38 AM
Black89Z51's Avatar
You can keep the existing upstream O2 sensors in the manifolds or by the manifold pipe prior to the turbo. You will want the WB O2 in the DP though.
