Top or bottom of wastegate for boost control
I use a 3 port solenoid. With no power it allows all the boost to the bottom port and none to the top. As it pulses it slowly limits flow to the bottom port while allowing more air to the top. When it's 100% closed it allows no air to the bottom and 100% to the top.
With a 3 port solenoid and no on board air this will give you the largest boost window. I can run 8-25 lbs this way... Sure I can run more but haven't tried more DC at this point. You do need a small bleed hole for the top chamber when plumbed this way.
I have since gone to this and have been very happy with it.
lots of different ways that all can work well.
A genuine GM 3 bar should read to 310kpa which is a little over 30psi.
during my 5 bar swap i spent some time digging in the source and this sensor should be much more accurate now, i learned a little better how the scaling works and how to datalog it more accurately.
