Comp Turbo Oiling Help
Old Mar 15, 2016 | 02:00 PM
mike63078's Avatar
Default Comp Turbo Oiling Help
Hi all I am looking for some help with my comp turbo and it over oiling.
I have a lq9 with a 76/79 comp CT43x billet wheel triple ball bearing turbo.
When I 1st set it up I ran a -4 line directly to the turbo. it over oiled on the dyno and blew the seals out. I send the turbo back and it was checked over and resealed. I just put it back on and this time ran a 0.030 restrictor to the turbo. It over oiled again on both side after running at idle for about 5 min. Not a lot but enough that it would only get worse.
The feed again is a -4 with a 0.030 restrictor, drain is a -10 strait up and down.
the PVC set up is a PCV on the drivers side and a a line from the pass side to the intake. the intake is a Edlebrock XT and the motor has a brian tooley stage 2 turbo cam.
any thoughts on what I can do to fix this?
Attached Thumbnails Comp Turbo Oiling Help-cold-side.jpg   Comp Turbo Oiling Help-hot-side.jpg
Old Mar 15, 2016 | 02:16 PM
rotary1307cc's Avatar
Sounds like a crankcase pressure issue to me
Old Mar 16, 2016 | 10:01 AM
transam69230's Avatar
At least tell the guy how to fix it!
What rotary is saying is you need some sort of catch can setup to vent the crankcase. Most guys run -12 hoses off the front of the valve covers to a catch can(s).
If you want to be fancy you could run evac setup and run it to the exhaust to help pull the excess pressure out.
Old Mar 17, 2016 | 09:54 AM
stevieturbo's Avatar
Well you could start with better info, it's like getting blood from a stone sometimes on these forums.
Where and how high is the turbo mounted ?
Oil drain size and route etc ?
Draw a proper schematic of any crankcase breathing system, often descriptions are just wrong.
And in virtually every case...same causes....and pretty much in this order.
inadequate drain ( few factors here )
inadequate crankcase breathing
excessive oil feed
Every now and again you could throw junk turbo in there too.
Old Mar 21, 2016 | 06:59 AM
mike63078's Avatar
Turbo is valve cover height. I have a -4 line in and a .030 restrictor. With a strait up and down drain then it goes to the rear side of my oil pan.
I'll keep investigating and see. Maybe it is the crank case pressure. I am just surprised at idle I would have that issue
