4l80
Old Mar 19, 2016 | 06:22 PM
vht's Avatar
vht
Default 4l80
I got a bid on a 02 3/4 ton 4x4 chevy. Rusty, but runs out good for 200, 000 miles. The trans has less than 10,000 on it, can you change tail housings and make it a 2wd? I'm going to part it out, I'll leave it together until I sell the eng, that way they can hear it run. The trans would bring decent money if it will go into a car without changing tail shaft or something big.
Old Mar 19, 2016 | 06:27 PM
twinturbo496's Avatar
The output shaft on a 4x4 trans is shorter, to use it on a 2wd you have to completely disassemble it and install the 2wd output shaft and then get a tail housing.
Note: Compared to 5 years ago the value of a 4l80e has dropped significantly, they are really only worth $200-300 as a core now. GM built more than 1000 per day for years, so the market is really saturated now...
And that question should have probably been in a different section.
Old Mar 20, 2016 | 06:42 AM
forcd ind's Avatar
The trans is prob worth more for a 4x4, they get hard use and usually could use a trans
You have to change the output shaft and tail housing (make sure the ring is on the shaft, 4x4 has it in the carrier)
Used rebuilt stuff is iffy, I just look at it as a core, unless I personally know something about it
Old Mar 20, 2016 | 08:07 AM
JoeNova's Avatar
Restricted User
To replace the output shaft, you literally have to remove evetything from the trans, as it is the last piece that comes out.
Trade it for a 2wd
Old Mar 20, 2016 | 12:53 PM
Taxman20's Avatar
Where are you located? I am about to pull the 4l80e from my S10 that works great. It will be for sale soon.
