Pure meth, IAT's and 2 step
Ron, does this truck run gas or E85?
By spraying after the IAT and seeing totally inaccurate charge temps you could never tune in any type of failsafe, crude or otherwise.
This is an Alky Control system with two nozzles. 10 and 15 gph.
In spite of repeated phone calls and detailed emails, our questions have been ignored. So bottom line on that, I don't know exactly how the setup works. It seems that it increases volume with boost.
If meth fails almost regardless of which method you choose ( worse being not spraying on IAT sensor ), you've instantly removed a ton of fuel and octane, and detonation suppression from a system that was reliant on it.
Things will get nasty.
And if as you describe your'e spraying onto the sensor and temps suddenly go from 100 to 200 deg ( baring in mind even so called fast sensors are still very slow in engine terms ), at least you could try and apply some failsafes based around these hot charge temps which is what you're doing and to me seems the most sensible approach
If the sensor never sees spray and always the inaccurate and high charge temps pre-spray, there is no possibility of any safety based around this...or any way really. Failure of meth flow in any shape or form will be catastrophic unless you are implementing some other form of failsafe externally based on actual meth flow.
Personally I prefer using actual charge temps so I’m always setup for my “worst case scenario” tune. There will never be a massive fluctuation in IAT’s this way. Closer than they would be if I were using data from a saturated sensor anyway. In the event of a pump failure, my WB02 failsafe would see I was more than a half point off my AFR target and would immediately drop my spark/boost. WB02 is much faster and better failsafe than the IAT sensor.
I’m not saying it’s necessary to keep most detonation free, just that it does provide more cylinder cooling.
Most aren’t spraying anywhere near enough to significantly effect charge temps as whole. You are closer to your actual charge temp by using a non saturated sensor.
Ignoring IAT's as you are and allowing them pre-spray....your tuning will always be on the aggressive side as if you lose meth, you've instantly lost the octane and cooling and the ecu has no idea it has happened other than the engine going bang because there will be no change in tuning or IAT whether it's spraying or not.
I just see that as a worst case scenario as far as safety goes.
I dont use either method really, I've different fuel/spark maps for whether I'm spraying meth or not and yes if charge temps do start to rise there will be some "safe" adjustments via IAT, but those would apply whether spraying or not and that approach is fairly generic.
If something did go badly **** up, closed loop correction and knock control would be sufficient to prevent any major damage, but I doubt it would even get that far. Or fractionally slower than that a lean lambda trip would be flagged and again reduce engine rpm and prevent any damage.
So either way I'm well covered.
Obviously factory ecu's and others dont offer people that though
For most part it's only at race tracks or higher grip locations or longer distance racing I use meth anyway. Everywhere else I dont need it or the extra power it can release.
Even at the weekend at a local airfield, warmish day for here and max charge temps I was seeing were around 120degF, that's ramping up to 25psi at end of run
Temps maybe around 80degF at start of run
I am not ignoring anything, I am monitoring actual charge temps post IC. I’m not spraying enough volume to significantly impact the charge temps enough to bother altering the tune. (most aren’t) Spraying 12gph pre TB isn’t going to do diddly to my charge temps as a whole or require a massive shift in my tune. Though the plugs prove it cools the CC quite a bit. That’s the purpose with my specific setup.
I understand Ron’s buddy is relying on the methanol, but a WB02 failsafe is a much better method than trying to use a slow IAT sensor as any kind of fail safe. That then frees up the IAT sensor to do its actual job and monitor true charge temps for proper SD calculations.
Sheesh. My head is spinning a bit. :-)
It a pump gas setup. We get 92 here.
I believe Forcefed is correct about the Alky system spraying in relation to boost.
The instructions however were very unclear about what the system is actually doing and how to set it up.
The IAT numbers do seem correct. Early in the day showed ambient at start up. I know these are hardly calibration grade sensors......
I'll see if I can find some real data on these turbos.
BTW, the turbos don't have access to outside air.
It would be great if I had equipment to data log temps pre IC, post IC and in the intake manifold itself to get a handle on what the primary issue is.
Like these...
http://www.ebay.com/itm/CXRacing-T4-...FS12ZG&vxp=mtr
Seems inline with the twin turbo LS kits cx racing sells as well.
http://www.ebay.com/itm/CXRacing-Twi...FUPz3F&vxp=mtr
http://www.cxracing.com/mm5/merchant.mvc?Screen=PROD&Product_Code=TRB-T72-P81-R_FLNG-OIL-FEED-AN4&Category_Code=TOCH
IC sounds suspect too. Would be a super cool test to pop that IC off, move the nozzles pre-compressor, and double the meth inj amount. If it has the 72’s on it I bet it picks up quite a bit at the same boost level. Even with lower timing
He can test further when he does license passes.
It doesn't build heat bad at all at 14 psi. I'll review some logs we did.
At 14psi, I'm seeing temperatures no higher than 20ºF above ambient with a CX Racing 31x12x4" IC.
