Pure meth, IAT's and 2 step
Old Mar 29, 2016 | 02:42 PM
  #41
RonSSNova's Avatar
Originally Posted by 67Firebird455
Sorry I didn't mention I'm not spraying methanol (yet), I was just curious if you all comparing numbers were using the complex style (IAT/ECT formula) or just IAT for your tune and logging.
To be honest, I didn't look at that part of the tune.
The PCM has a truck OS from 2002. 3 bar of course.
I'll check this evening
Old Mar 29, 2016 | 02:46 PM
  #42
67Firebird455's Avatar
Awesome, appreciate it. I want to make sure we're comparing apples to apples here.
Old Mar 29, 2016 | 09:46 PM
  #43
RonSSNova's Avatar
Cyl charge temp complex model is enabled. Settings are stock and it's biased towards IAT.
Old Mar 29, 2016 | 09:53 PM
  #44
Interesting, just took mine for a drive (again, on 91) again, here's the hptuners log, and config.
File Type: xml
File Type: hpl
Old Mar 29, 2016 | 09:58 PM
  #45
I'm curious why your IAT numbers are so much higher than mine. I'd be freaking out if I were seeing them as high as yours on the truck. Can you get the methanol to come on later like 10psi or so so when you stand on the 2-step you've got some margin in there with it off? I'm still for having the nozzles before the sensor, but as you previously mentioned, the best spot for the IAT is in the manifold, hands down, then you wouldn't use the complex method.
Old Mar 30, 2016 | 06:09 AM
  #46
kingtal0n's Avatar
This
Originally Posted by JoeNova
The moral of the story is was giving is that you put the IAT before the meth nozzle, and then don't tune based on the meth. You tune for high IAT without the methanol injection on, and then use the methanol as supplemental fuel/safety cushion.
Is how a daily driver should be set, such that if the meth runs dry, you are still in a safe region. Very good way to setup a reliable combination for daily service.
The only con is that the tune is typically "too safe", when the meth is actually on, you are leaving some power on the table, there is a trade off between safety and output. That is how we distinguish a competition vehicle vs daily drivers: competition calls for every trick to be used, we will push the meth to it's limit, and the engine will not be safe all else being equal without it.
In both cases, F@(#* the IAT sensor. Sure, if its there, look at it. But don't use it to tune anything except cold weather/cold start conditions. When IAT climbs the OEM solution is to pull fuel. Funny, because when Coolant temps rise too high we typically add fuel. Its like they cant decide which way to go with it.
Old Mar 30, 2016 | 10:36 AM
  #47
RonSSNova's Avatar
Your IAT never seems to change at all.
At any rate, you won't see a huge temp rise on short blasts while driving around. Remember, we are running laps and going 1/4 miles at a time at 23psi.
The IC gets heat soaked.
Next test we need to figure out how to measure temps on the inlet side of the IC.
And yes, we will reset the meth so it starts at a higher boost level.
Old Mar 30, 2016 | 10:41 AM
  #48
I'm definitely interested in hearing what change(s) you make to get this resolved man, that's got to be frustrating. You're right, I'm on city streets so doing much over 100 for short bursts is really sketch. You're also right that 23psi is a whole different ball game. =( I hope you can get this ironed out man, I really like your setup.
Old Mar 30, 2016 | 10:57 AM
  #49
Forcefed86's Avatar
Metal thermocouples and a fluke meter are a good quick way. The metal coolant sensors are too slow and the IAT sensors melt.
http://www.alliedelec.com/fluke-80bk...FQ8vaQod6KoB7A
Old Mar 30, 2016 | 12:18 PM
  #50
stevieturbo's Avatar
If your pre IC charge temps really are that bad, just slap a few thermocouples in them, if you get the ones with the small tip they're pretty fast acting.
Innovate TC-4 is fairly cheap and will let you run 4 thermocouples.
http://www.innovatemotorsports.com/products/tc_4.php
Although still a fairly expensive test excersize.
Old Mar 30, 2016 | 02:20 PM
  #51
ZNix's Avatar
Do not spray methanol on the 2-step. It will kill spool and may even bog you off the line. Best way to setup the meth is to turn it off during 2-step operation. The Alkycontrol kit has a purple wire, that when grounded, kills the pump. If I remember correctly. Add this to your 2-step switch/button and it should cut the alky when building. Once you let off the 2-step, the alky will trigger as per usual. Moving the trigger pressure up will just make it take longer for methanol to ramp in. IMO, I would want alky firing as soon as boost hits off the 2-step.
Old Mar 31, 2016 | 12:37 AM
  #52
RonSSNova's Avatar
Used those types of thermocouples many times.
Prob something I should have in my toolbox.
Old Mar 31, 2016 | 01:15 PM
  #53
roastin240's Avatar
Didnt read the whole thread so someone may have said this already....but you could throw a T-Type (blue - read up to 872 deg F) thermocouple with a swagelok fitting in the intake manifold downstream of the METH nozzle, and temporarily read it with a cheap multimeter that has a thermocouple input. Then you will know where your actually at.
I spray my stock MAP sensor in the manifold on my ecoboost and have no issues. I like it that way so I can monitor and tune for real intake manifold charge temps and will see if the nozzle gets clogged or the system fails based on IAT's.
Old Mar 31, 2016 | 03:17 PM
  #54
RonSSNova's Avatar
Actually, I'm not frustrated. The owner is. :-)
I'm just the tuner.
Sadly he doesn't live close, so I'm not hands on with it.
Old Mar 31, 2016 | 04:11 PM
  #55
I'm just the tuner.
The lack of much of a lip on that TB and a thin T-Bolt clamp are what's causing that. Poor owner.
Old Mar 31, 2016 | 05:00 PM
  #56
RonSSNova's Avatar
Thank you! I did not install the kit. This is good to know.
Ron
Old Mar 31, 2016 | 05:02 PM
  #57
RonSSNova's Avatar
You respond to the wrong post?
Old Apr 1, 2016 | 12:13 AM
  #58
WTH? LOL I have no idea how in the **** that happened. Sorry man.
EDIT - Seriously what the hell? That was in response to JoeNova's other post with the S474! LOL Sorry buddy.
Old Apr 1, 2016 | 10:33 AM
  #59
RonSSNova's Avatar
Ha! That's what I figured.
