Huron Speed T4 Scavenge pump location????
I'm going to install a scavenge pump but I don't really know where to put it. Any of you with the T4 A/C kit install one have any pics of a location? Thanks!
I've always blown a little bit of oil through the turbo with this kit. I put the drain on the oil pan as high as I could on the side though oil still drains from it. The Mighty Mouse can almost eliminated the oil but I still need it.
You can probably msg Jon from Huron and see what he says. But he told me that I don't need one and I'll be fine with his kit and the Mighty Mouse.
So far mines good and my buddies turbo setup that he built himself is setup just like the t4 we have and he's been running it for years.
I've also had a lot of oil seepage with that same kit- even with the MM catch can. Been in touch with both Jon and a tech at Turbonetics, and the suggestion by the T-netics tech was to use no -AN fittings with an angle more severe than 45*. The drain kit which Huron provided used two 90* fittings- I'm hoping that a 45* off of the drain helps to speed up the drainage some, though I'll likely keep the 90* running into the pan unless the turbo's still puking oil.
Huron Speed V1 with a PT88....never used a scavenge pump, never had an issue. We used a better location than what Huron Speed suggested for the oil drain spot though. Also used custom lines vs the ones supplied. Happy with the product.
