Question For Those With A BOV
Old Mar 22, 2016 | 08:35 PM
2JZFC's Avatar
Default Question For Those With A BOV
Do you use a check valve in the vacuum line?
Old Mar 22, 2016 | 11:51 PM
67Firebird455's Avatar
I never have.
Old Mar 23, 2016 | 12:16 AM
Cyrperformance's Avatar
No, I believe depending on which direction it is installed, it can hold it open or not allow it to open properly.
Old Mar 23, 2016 | 06:22 AM
dt23400's Avatar
^ hes right. the pressure built from the turbo is what holds the bov shut. Once you release the throttle there is no more pressure holding the valve shut so it opens and releases the excess pressure in the charge pipe. a check valve only lets the air travel one way therefor rendering the bov useless.
Old Mar 23, 2016 | 07:39 AM
2JZFC's Avatar
Thanks guys.
