Great N/A - Now want boost
If its just for fun and you intent to keep the chassis, worry less about the "front end weight" as you are putting it and put more effort/time into the suspension (if handling is a concern). You can get a heavy vehicle to perform well but it takes time/effort/patience in the suspension parts and seems to cost more than a light weight car, which can often get by reasonable well without effort. Adding a turbo and all that weight that goes with it (or any FI setup) is against the "light chassis" idea, if you arn't going to lighten it up by cutting it up/welding on it, and if being light and cornering is more important you run the aluminum N/A block and keep power minimal (where you are now). You literally said "sacrifice raw power" thats exactly where you are, just add nitrous to taste seasoning/flavor to the capacity of the engine.
Even if just a 50-75 progressive shot and a really cold intake manifold, plenty of chill in there and you will easily max the block capacity while maintaining the existing engine for a little while longer while you decide how you want to spend the next 10 or 20k. If you have that faith in the current engine.
If its just for fun and you intent to keep the chassis, worry less about the "front end weight" as you are putting it and put more effort/time into the suspension. You can get a heavy vehicle to perform well but it takes more time/effort/patience in the suspension parts. Adding a turbo and all that weight that goes with it (or any FI setup) is against the "light chassis" idea, if you arn't going to lighten it up by cutting it up/welding on it, and if being light and cornering is more important you run the aluminum N/A block and keep power minimal (where you are now). You literally said "sacrifice raw power" thats exactly where you are, just add nitrous to taste seasoning/flavor to the capacity of the engine.
As for using an L33, would those sleeves still handle boost if bored to 3.904 so I can re-use my current rotating assembly?
L33 block
Forged pistons and rods
Stock crank
243 heads.
See this thread for a small bit of help:
http://www.lateral-g.net/forums/show...t=52628&page=2
Also, is there any problem going FI with the FAST LSXr intake?
The 5.3 aluminum blocks seem to be able to take a real beating. There are lots of them out there pushing 1000 whp. If you want to stay aluminum, they are your best bet.
You would want to use the 5.3's smaller bore to maintain the thicker cylinder sleeves. If you bore out the 5.3 sleeves to 3.9", then you are right back where you started with thin *** sleeves. Keeping it small bore gives you more "meat" around the cylinder for strength.
Or, just retune your spring and bar package to use an iron block. The weight can be compensated for when tuning the suspension.
