Manual boost controller 20psi Max?
Old Apr 19, 2016 | 11:46 AM
3 window's Avatar
So I offered to do some updates to this car. It's in my garage now.
I'll be wiring in the boost controller as well as adding a new electric fan.
To do that I neede to rebuild the hot side.
Someone mentioned boost leaks?
I found no less than 30 leaks in the welding job. Along with one large crack.....
The cold side not too much better.
Amazing it makes the power it does. Should be better when I'm done!
Yah, I'm thinking you should wear a cape to the next dyno session. You're gonna be this guy's hero! Nice job on finding all the issues. You do quality work.
Old Apr 20, 2016 | 07:38 PM
rpturbo's Avatar
Yeah, it's amazing you had that much boost. Better be careful now, you'll have more boost than you know what to do with.
Old Apr 21, 2016 | 09:49 AM
RonSSNova's Avatar
We shall see.
I'm just fixing the manifold welds. They look like hell, but won't leak.
The crossover will be new.
Although the sloppy style isn't my first choice, it works fine. But needs to be at least done correctly.
The down pipe was worse. I wonder if we ever got any accurate AFR readings.
Old Apr 21, 2016 | 10:10 AM
Forcefed86's Avatar
Need one of those “HellenKellerFab” stickers on it when you’re done!
Old Apr 21, 2016 | 06:07 PM
RonSSNova's Avatar
That's hilarious!
