Procharged Header opinions
Old Apr 14, 2016 | 09:40 AM
ICRAZY6's Avatar
Question Procharged Header opinions
390 iron block
D1sc pushing 13lbs
317 heads
Brute Speed blower cam
1 3/4" pacesetter headers, no cat Y-pipe, Magnaflow exhaust.
I'm looking at 1 7/8" and wondering if there's much to be gained by switching to them from my 1 3/4" pacesetters? I know my boost level will likely decrease, but will there be more power made? Speed Engineering has them for $400.
Just seeing what everyone thought is before I pull the trigger.
If someone has a dyno comparison that would be helpful as well.
Thanks!!!
Old Apr 14, 2016 | 10:24 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I don't think the gains will be enough to justify the cost and hassle until you're running more boost than you are. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Apr 14, 2016 | 02:46 PM
Rise of the Phoenix's Avatar
On NA setups, switching from 1 3/4" headers to 1 7/8" headers have seen as much as 25+ rwhp gains. I'd think on a Procharged setup, the gains would be even greater.
Old Apr 14, 2016 | 03:52 PM
LS1Tech Sponsor
I never saw much of a difference in the lower end (cheaper) headers myself, unless a lot of boost was being used. Bob
__________________
Old Apr 14, 2016 | 04:20 PM
Mike 02T/A's Avatar
I never ran 1 3/4" headers, went straight to TSP 1 7/8".
My exhaust also dumps before the axle, Kooks 3 inch bullet mufflers. Like mentioned, it might not be worth the money. I do regret not buying a stainless set like Kooks, etc.
Old Apr 14, 2016 | 06:18 PM
Detoxx03's Avatar
1 7/8 for sure. A friend of mine has the little ones on his car and we have almost identical setups and mine makes more through the midrange and up top. You never know when you'll upgrade power levels so just get them from the beginning.
Old Apr 15, 2016 | 01:35 AM
Blown06's Avatar
8 Second Truck Club
I'd put a 2" on it.
Old Apr 15, 2016 | 12:26 PM
King23's Avatar
Originally Posted by Blown06
I'd put a 2" on it.
^^ this if your going from a 1 3/4 header, wouldn't it be better just to go 2" for later down the road if you ever want to step up to a f-series blower.
Old Apr 15, 2016 | 09:45 PM
DavidBoren's Avatar
2" primaries make sense for a boosted 390ci. I would run them if you can.
Old Apr 16, 2016 | 03:12 AM
Blown06's Avatar
8 Second Truck Club
My .02
Header primary size/length is an important thing on an N/A combo as the scavenging effect can create some additional power.
On a blown application, scavenging is moot point. During valve overlap the boost or pressure on the intake side is just pushing additional air/fuel out the exhaust. There really is no such thing as scavenging in the exhaust system as there is never a depression in the exhaust system that is significant enough to help pull additional air/fuel into the cylinder during overlap.
In my camp, if the motor has a blower on it, use the biggest header you can fit/afford. There will not be any power loss anywhere by going bigger.
*Note: This theory of mine does not apply across the board as long as the motor is boosted. In other words.......boost from a turbo requires a whole different theory. I'm speaking only in terms of supercharged combos.
Old Apr 16, 2016 | 06:33 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
For $400, and a Saturday afternoon in the garage, it's worth it.
I ran 1 3/4 headers on my 347/D1 combo at 16.5psi, and made 760/700, but might have made closer to 800 if I had bigger headers.... is it worth it, maybe.
Trust me, I understand the debate. Right now I've had the same debate with myself over my intercooler for the past 4-5 months. I have a cheap ebay one, and could probably gain 2-3psi up top with a better one, but do I really need more than 860rwhp?
Old Apr 16, 2016 | 07:19 AM
lmt0705's Avatar
Um.....yes! Lol. Who doesn't need more than 860???
Old Apr 16, 2016 | 09:51 AM
UNDER PRESSURE MOD
Well, I'm at the limit of fuel system as well. So more power would mean a major upgrade fuel wise as well.
Old Apr 16, 2016 | 10:50 PM
conan's Avatar
Often wondered how much my exhaust is holding back. 1-3/4 Kooks 3" off road Y and a Hooker catback. I've looked into Kook's 2'' header with their 3" dual behind them but its a pricey upgrade.
Old Apr 17, 2016 | 02:26 AM
Blown06's Avatar
8 Second Truck Club
I really sat back and thought about this for you for like 4 hours. I decided that yes, you really need more than 860 rwhp.
Old Apr 18, 2016 | 11:32 AM
UNDER PRESSURE MOD
Yeah, it's kind of like sitting at a bar 5 minutes before last call, 8 or 10 drinks in, and deciding if you need one more.
Old Apr 18, 2016 | 11:42 AM
TXsilverado's Avatar
My .02
I have zero proof, but this is where my head is at. i'm pulling 1 3/4 off of my blown 408 for a 2" primary, 3.5" collector and dual 3.5" exhaust through bullets.
Old Apr 18, 2016 | 11:59 AM
conan's Avatar
You plan on sharing your results when the swap is complete ?
Old Apr 18, 2016 | 12:11 PM
ICRAZY6's Avatar
I would be interested in see those results as well.
Old Apr 19, 2016 | 05:31 PM
sure, but it wouldn't be an apples-apples comparison. the current setup is 1 3/4 with 3" duals H pipe and I think 80 series flowmasters (bought it this way). next setup with be a straight through muffler with an X. not really a fair comparison. also 2 different dynos, 2 different tuners and more meth this time around.
