MS3 Pro setup on twin s366 build
Old Apr 16, 2016 | 01:57 AM
NCTransAmMan37's Avatar
Default MS3 Pro setup on twin s366 build
Alright so I've recently decided to steer away from my fox build, and got back into the f body game. Bought a 2000 Trans Am roller, moly 10 pt, 35 splined 9", tube front end, setup with twin s366s. Just looking for help on setting up/ buying the right parts that I'd need for my ms3 pro. This is the first time I've used an aftermarket engine management system.
Is it better to run 2 boost solenoids or a single solenoid?
Anyone know how to set it up initially as far as what ignition setup etc?
Old Apr 16, 2016 | 01:59 AM
Pic of the setup
Old Apr 16, 2016 | 05:34 AM
SCott5's Avatar
I was wondering who bought Stephens car off johnathan. Can't wait to see the progress
Old Apr 16, 2016 | 06:20 AM
dburt86's Avatar
With my twin setup, I ran 1 solenoid and split the tubing. It works great. 3 port solenoid, 1 port gets fed from the compressor housing, another port splits to the bottom of the gates, and the other gets split to the top of the gates
Old Apr 16, 2016 | 10:58 PM
1bdbrd's Avatar
What are you planning for gauges? Ms won't control the stock cluster because it's not CANBUS.
Old Apr 18, 2016 | 07:30 AM
I've got a custom 8 gauge setup from Speedhut. Boost, tach, speedo, water temp, oil press, oil temp, volts, and fuel level.
Old Apr 18, 2016 | 07:31 AM
Yea I'm pretty excited about it man. Gunna see how much this SBE lq4 can make, then throw a forged shortblock in it. Should be a fun car
Old Apr 18, 2016 | 07:32 AM
Just clarifying you're using the ms3 setup right? With their solenoid?
Old Apr 18, 2016 | 07:42 AM
kainedogg's Avatar
Looking forward to the MS3 pro updates.
Old Apr 18, 2016 | 10:13 AM
dburt86's Avatar
Yea, mines the gold box but same thing really
Old Apr 20, 2016 | 10:28 PM
elkydragger's Avatar
I have the gold box too. Twin 369sxe 365" ls2 straight methanol 1500hp top dragster! I am still building so I am not much help, but I am in for updates.
Old Apr 21, 2016 | 11:03 AM
antone use the unterminated harness? Instead of the "drop on" harness? Looking for a clean way to setup the fuses/relays on it.
