turbo Idea!!
turbo Idea!!
Well I might do it. Been looking around, ebay mostly. I know have ask before, but would 2 smaller turbos work. Or two furd powerstroke turbos.
The price is looking better and better just for the turbos. Yes I know there is going to be custom work, the main reason for doing is the custom work. This for a 8100 vortec.
been seeing alot of new twin turbo packages. to4's garrett exhaust has a 1.15a/r and compressor has a .61 A/R $575.00
What do you think???
I ruin the end of films...
I always thought there was some weird oil line issues w/ the Powerstroke turbos? I remember reading about it on TurboMustangs, but never looked into it since I had no interest in it.
How about this one!!!
Garrett/AiResearch TV81 Turbocharger
New Remanufactured Unit!
Turbo Specifications:
Cold Side:
T18A, 62 Trim Compressor Wheel -3.348 in. (85mm), Inducer, 4.250 in. (108mm) Major
0.95 A/R Compressor Housing
5.25 in. Inlet and 3.5 in Outlet
Hot Side:
Big-Shaft 75 Trim Turbine Wheel- 4.364 in. (111mm) Major, 3.827 in. (97mm) Exducer
1.60 A/R Turbine Housing w/Tangential Scroll
Standard Large-Frame (Thumper) inlet, bolt spacing about 4.5 in. x 2.75 in.
Bearing Section
Oil Lubricated and Cooled
Garrett Model TV8101
Cold Side:
Hot Side:
Bearing Section
LS1TECH Sponsor
Well thats a very large turbo, and the A/R is huge. I can get the smaller A/R version, but they take some time, since most of those units are set aside for Detroit Diesel.
Jose
Jose
