Intake air temp non intercooled
They were only holding the pro tree .5 seconds before dropping it so we were leaving on .5-1 lb of boost and in full boost by 1.0 seconds into the run.
The last run we turned the boost up another .5 lb and it went a little fat and didn't pick up as much as we expected went from 11.1 to 10.4 afr
We shifted it at 6400 and went through the traps at 7000 (stock rod bolts)
Just asking why will pump gas not be happy in the 11.1-10.5 range. I know that's on the rich side but I feel one pass lean at 225* intake temps might be its last.
