Is it worth it to upgrade to fast intake?
Old Jun 14, 2016 | 07:05 AM
JoeNova's Avatar
Restricted User
A buddy of mine fit a TBSS intake on his GTO. It hit the hood where the throttle body is, since the TBSS throttle angles upward slightly. He made it work somehow.
Old Jun 16, 2016 | 12:53 PM
Nismo Kid's Avatar
Here's a cracked fast from my friends turbo'd GTO on moderate boost. Fast manifolds are great for a NA build, but on a FI build they tend fail often. I've seen all sizes crack. I'd avoid the Wilson Manifolds due to fitment issues. Another to avoid is the typhoon/ pro comp they tend to leak under boost. Unless you have the bottom machined & drill more holes to secure the plate on. I'd rock another stock manifold. Or get a Vic Jr. with a Aarons elbow. That way it clears your cowl. A properly ported Vic Jr will match if not outperform a Fast.
Old Jun 16, 2016 | 02:58 PM
stevieturbo's Avatar
The above pic looks metal ?? Or is it some sort of paint ?
Which FAST is it ?
I changed from carb intake to BBK, the steel bottom plate was crap so I made a new thicker 5mm aluminium plate instead. So far a few runs at 26psi and it has held up find. Also bonded it on with some Loctite flange sealant.
Old Jun 16, 2016 | 03:09 PM
Nismo Kid's Avatar
Which FAST is it ?
Fast 90. It cracked on the underside of the manifold.
At least it w was an easy fix on the BBK.
Old Jun 16, 2016 | 03:35 PM
Are the later fast models not supposed to be a lot stronger than an early 90 ?
Old Jun 16, 2016 | 04:57 PM
Nismo Kid's Avatar
Yeah they are. Unfortunately that not strong enough. I can't even count how many local guys have had problems with them on 2 hands. I'd have to start using my toes lol
http://www.yellowbullet.com/forum/sh...=760202#/enter
Old Jun 16, 2016 | 05:12 PM
Nismo Kid's Avatar
I'm not claiming they're made of glass. But make sure you document proper installation & receipts if it was installed by a shop. If not you may find yourself up a creek without a paddle. If your willing to risk 800$ go for the fast. Remember plenty of people have made plenty of power on stock manifolds( ls1, truck, TBSS, Etc.)
