How to run your PCV to the downpipe for evacuation
Old Jun 28, 2016 | 07:50 AM
rotary1307cc's Avatar
Originally Posted by Blown06
Are you saying that it doesn't create a depression at all that is quantifiable (measurable)?
Do you have any back to bad data logs with a press sensor in the crankcase to prove or verify?
I don't have a transducer. Yes it makes a small depression, easily seen by if you hold a bag up to the port. But nothing significant like a couple inches of vac
Old Jun 28, 2016 | 07:53 AM
I have never noticed any rank smell and I have loaded my mufflers in the past before when I had the breathers on the valve covers at thr very rear
Old Jun 28, 2016 | 10:39 AM
93camaro_zzz's Avatar
Good discussion guys. I have been reading a lot of people having success with this over at the bullet. Most people are actually able to read a vacuum. Usually it is not much, but I figure even if I read 1-2inches of vacuum, that this would be a cheap success. Keep it comin!
Old Jun 28, 2016 | 12:01 PM
SethU's Avatar
"Should" definitely work. There are a couple opposing principals at work specific to turbo applications, but yes it should work for what your expecting.
The opposing factors I see, and mind you it's a speculation...
It will be more effective with higher exhaust velocity. Exhaust velocity increases with a smaller diameter exhaust tubing which is in conflict with minimizing downstream pressures for a turbo deal.
That said, 600+ hp worth of exhaust gasses through a single 4", should work just fine. A 5-6" downpipe might be a completely different story. There are plenty of NA engines that achieve 5"hg with one tapped into each 4" collector that aren't making 600+... I assume velocity will be sufficient in your case.
I look forward to hearing about the results. Fun stuff!
Old Jun 30, 2016 | 09:04 AM
Don't get me wrong I love mine and wouldn't change it
Mine works well because I have a full length 3" exhaust that the breathers tie to. But I also have a 4" fender dump on an electric cutout
So I always have high velocity across the evac, just no real chance of high pressure.
Even at idle with the dump open i still maintain good velocity out the full exhaust
Breathers go directly from valve cover to exhaust. I have the covers baffled inside
