Procharged Compression Advice
Old Jul 10, 2016 | 06:47 PM
Spade's Avatar
Default Procharged Compression Advice
Building a procharged 370 LQ9 to be daily driven. What do you guys recommend for compression? I have seen anywhere from 9.5 to 10.1 for boost motors. Thoughts?
Old Jul 11, 2016 | 01:03 AM
Detoxx03's Avatar
What fuel and what headunit? If 93 octane no lower than 10.0:1 and if e85 higher than that.
Old Jul 11, 2016 | 01:22 AM
Spade's Avatar
91 is the best we have here. D1SC unit.
Old Jul 11, 2016 | 07:14 AM
conan's Avatar
I'm running 10.1:1 compression on 91 octane, no problems. I wouldn't go any lower if I were doing it all over again as well. My car is 99% street car, part throttle and low RPM driving is nice and crisp.
What elevation are you at in NM ?
Old Jul 11, 2016 | 07:34 AM
oscs's Avatar
On 91 I would keep it around 9.5 unless youre trying to break records. No reason in risking detonation. You want more power just turn the boost up. Remember, You can't "turn down" compression.
Old Jul 11, 2016 | 01:56 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
Can you afford to put a meth injection kit on it?
If not, I would stay in the 9.5:1 range. Our LS2 is still at its factory 10.9:1 and I am running 30% ethanol and propane on top of 91 octane to compensate. Keep in mind that static compression ratio (pistons, heads, and HG thickness) is going to be higher than your dynamic compression ratio (valve events) - and this will impact your octane:knock tolerance.
Old Jul 11, 2016 | 02:01 PM
Detoxx03's Avatar
Methanol with definitely help. Before I switched to e85 I was on 93 and ran 100% meth. Made a good 780 easily on the stock 10.7:1 compression. Now on the same compression on corn make almost 900 on less timing.
If no methanol then you can play it a little more conservative.
Old Jul 11, 2016 | 02:07 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
9.5/1 is a good compromise for you with 91 octane. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Jul 11, 2016 | 05:52 PM
Spade's Avatar
Thanks for the input guys, I honestly have not looked at doing meth injection. Figured it would just be to much of a hassle and the fact I know very little about it. I would like to just fill the car up at the gas station and drive it around like I stole it and not worry to much about anything else.
Would 9.5/1 feel slouchy driving around if not in boost or do you think I really am not going to feel it much? To be honest I really don't know how much I would be out of boost anyways.
Old Jul 11, 2016 | 06:01 PM
LS1Tech Sponsor
A tank of meth usually last quite awhile as it is only used when deep into the throttle. Alky Control has one of the best kits you can buy, they're in Florida. Give Julio a call there and he'll answer any question you have.
9.5/1 doesn't feel weak down low to me. Bob
__________________
Old Jul 11, 2016 | 09:40 PM
malibu9in's Avatar
Auto or stick?
Old Jul 11, 2016 | 10:23 PM
Spade's Avatar
Sorry never did answer your question, 4200 feet
Old Jul 12, 2016 | 12:57 AM
Detoxx03's Avatar
Originally Posted by malibu9in
Auto or stick?
Stick
Old Jul 12, 2016 | 01:17 AM
Monte4ever's Avatar
I run 9.5 comp and have real good bottom end grunt. I do have a 403 thou.
Old Jul 12, 2016 | 05:04 AM
malibu9in's Avatar
Stick
What kinda clutch you running? Is the pedal hard? Gonna swap a clutch veeerryyy soon. Thx
Old Jul 12, 2016 | 06:55 AM
conan's Avatar
I live at 6,300 and drive on a road that hits 7,500 daily. One more reason I chose to keep the compression up on my new motor, making power up here where planes fly is tough.
Like Bob said it takes quite a bit to burn through a tank of meth, so don't be afraid that its something you'll have to fill all the time. I have a 3/4 gal tank for my Snow meth kit and it lasted me all of last summer, about 1,200 miles of hard driving. You can also set what psi you want it to turn on at, so my pump doesn't even kick on until 4 psi. I would look in to a kit for your set up, it's worth the insurance for sure.
Old Jul 12, 2016 | 09:21 AM
Detoxx03's Avatar
Mantic 9000 twin. Pedal feel is about the same as stock.
Old Jul 12, 2016 | 11:02 AM
malibu9in's Avatar
thanks for rply
Old Jul 12, 2016 | 11:04 AM
kingtal0n's Avatar
this!
Lots of people say "I wish I built it with a little less compression"
very few will say "damn I wish I had an extra half point of compression"
Old Jul 13, 2016 | 12:31 AM
Spade's Avatar
I greatly appreciate the input folks.
