Darleen Z28 370 E85 S476 9.17 @ 147 so far...
Old 07-26-2017, 08:29 AM
  #121
Nitroused383's Avatar
I won't disagree with you there. At 20 psi I was seeing 1.8:1 back pressure around 6500 and 2:1 at 7000. I just wanted to see what it would actually make so I put pressure only on top of the gate. I only stabbed it for a few seconds and I'm it spiked from the exhaust valve floating. Everything I've read says when back pressure suddenly spikes crazy it's from exhaust valve float. People have made 25 psi with this same turbo on a 6.0. Even at 20 psi it still gains 25 hp per psi.
Old 07-29-2017, 12:28 PM
  #122
RonSSNova's Avatar
Originally Posted by Nitroused383
I put the shock settings in the video title but the last pass was 1 from full tight. They are just qa1r on the front so I will eventually have to upgrade to much slower valving. From what I understand you want full shock extension right before the 60' mark.
Makes sense to me. I see a lot of cars that spin right after the front tops out way before the 60ft. Mine included.
I have the Viking DA front shocks. Last week I added three clicks to the extension, and I couldn't even pull the front end up by hand. Sadly, I didn't get to race the car.
Old 07-29-2017, 01:25 PM
  #123
I will be racing today and tomorrow so I have lots to play with. I shimmed all my valve springs up, finally finished last night. What a **** that was. Almost all of my springs were at 160 seat except 2 of them on #4 cylinder were 10 lbs less. Kinda odd but most of them are now 180 / 430. There is noticeably more valve train noise. In my quick test hit in 2nd gear the converter flashed 400 rpm higher than it previously has been under boost.
Its probably placebo but it seems to rev much faster but we will see what it does today in this heat. Track should be prepped well and maybe I can squeeze an 8 second pass in.
Old 07-30-2017, 06:05 AM
  #124
So I think shimming the springs was a bad idea on these comp 850 lifters. I'm not sure yet but the top end is making some unpleasant noises now. I will be pulling the heads, hope it isn't too bad. I did get my car to leave well and I was creeping up on some nice 60' times. Some day I will beat the orange car ;D
Old 07-30-2017, 08:02 AM
  #125
RonSSNova's Avatar
Set him up with a 13 second tune.....
Old 07-30-2017, 09:49 AM
  #126
smokeshow's Avatar
I feel like valve float gets blamed more often than it should.
Old 07-31-2017, 09:26 PM
  #127
Engine needs to come out, bearing material in the filter. Looks like I spun a bearing somewhere. Odd thing is it didn't lose any oil pressure.
Old 07-31-2017, 09:58 PM
  #128
Game ova's Avatar
You didn't necessarily lose a bearing. I know it sounds silly, but I have what looks like glitter oil EVERY oil change. Got paranoid and didn't trust the motor last year and pulled it down, EVERY bearing was perfectly fine. Will probably get flamed but it's true. Now, I don't even sweat it, was actually pissed that the bearings were fine..... but hey...better safe than sorry.
Old 07-31-2017, 10:35 PM
  #129
Last filter my 300 miles ago had nothing in it at all. This one..
Old 08-01-2017, 12:03 AM
  #130
Old 08-01-2017, 07:15 AM
  #131
alocker's Avatar
I'm confused. Did you get a 8 or did it blow up?
Old 08-01-2017, 08:32 AM
  #132
No 8 but close, I was just uploading videos from the weekend. It didn't exactly blow up I just heard a faint ticking on the top of the motor after my solo pass so I trailered it home. That's when I cut the filter open and saw metal. I drove it 45 mins to the track in 95 degree heat and these were my passes
Old 08-01-2017, 08:26 PM
  #133
RonSSNova's Avatar
Perfect rumpled up time slips!
Bummer about the metal in the oil. Glad you heard the change in noise and checked.
Get signed up for West Coast Shootout 2 in Sept. Going to be a good time!
Old 08-01-2017, 10:10 PM
  #134
truckdoug's Avatar
wow looks like a stripper spent the night in your motor
Old 08-01-2017, 11:40 PM
  #135
LOL I shoved all of them in my pocket because they didn't have an 8 on them!I found a 05 5.3 with 250k miles I'm thinking about picking up to throw in her. I will be on vacation during that time and I'm not even sure when I will be able to get the car going again.
Old 08-02-2017, 08:37 AM
  #136
C5_Pete's Avatar
Sorry to hear of the possible carnage. Best of success with the rebuild.
Old 08-17-2017, 09:48 PM
  #137
Still haven't had a chance to work on the car but I have listed my turbo up for sale. Kinda sad I never got to run an 8 with it but oh well https://ls1tech.com/forums/parts-cla...t-s476-t6.html
Old 08-18-2017, 08:03 AM
  #138
RonSSNova's Avatar
Panning on a bigger turbo?
Old 08-18-2017, 09:57 AM
  #139
Old 08-24-2017, 05:00 AM
  #140
slowlsx's Avatar
What injectors at what baseball pressure? How far have these dual walbro 450's taken you and what duty cycle are you at right now?
Quick Reply: Darleen Z28 370 E85 S476 9.17 @ 147 so far...
