Boost issue
Old Aug 2, 2016 | 07:09 AM
48rat's Avatar
Default Boost issue
Ok guys. Man boost controller. And I can't get above 15psi!! Any suggestions??
Old Aug 2, 2016 | 07:10 AM
JoeNova's Avatar
Restricted User
Add more wastegate spring or buy another boost controller.
Old Aug 2, 2016 | 07:12 AM
48rat's Avatar
I made my boost controller. not sure if that makes a diff. and I believe its a 44mm wastegate.
Old Aug 2, 2016 | 07:21 AM
48rat's Avatar
just trying to understand how it works!
Old Aug 2, 2016 | 07:27 AM
48rat's Avatar
the spring in it right now is a 8-9# I believe.
Old Aug 2, 2016 | 07:38 AM
JoeNova's Avatar
Restricted User
You can buy decent manual boost controllers on ebay for $20-25.
Do you use a ball and spring design?
Old Aug 2, 2016 | 07:40 AM
48rat's Avatar
that's what I made. watched a you tube video. seemed pretty simple
Old Aug 2, 2016 | 07:59 AM
JackrabbitSlim's Avatar
Like what was stated above, add more wastegate spring. 15ish is about all that you can milk out of an 8 pound spring. A manual boost controller can generally "double" the spring's opening pressure, so 15 psi is about par for the course.
 Michael S. Palmer
Old Aug 2, 2016 | 08:01 AM
48rat's Avatar
Ok. I guess that's what I needed! Lol. Also is there a waste hate to turbo ratio for size??
Old Aug 3, 2016 | 05:17 AM
stevieturbo's Avatar
I suggest you give us some proper details and useful information.
Old Aug 3, 2016 | 07:53 AM
48rat's Avatar
sorry Stevie turbo. I guess I wasn't born out of the womb knowing everything there is to know like evidently you were! ill stick to the guys that have been polite and not sarcastic!!
Old Aug 3, 2016 | 08:16 AM
Some people really are dumb. How the **** can anyone give a reliable answer when we know **** all about the setup?
What engine, turbo, gate, controller, how is it all configured.
We dont all have crystal *****.
Old Aug 3, 2016 | 08:52 AM
JoeNova's Avatar
Restricted User
Switch boost controllers and wastegate springs. That simple.
A proper boost manual boost controller will be able to restrict flow down enough to keep any manifold pressure from going to the wastegate.
But if you have a weak *** spring and lots of exhaust backpressure, the exhaust will push the gate open.
Old Aug 3, 2016 | 09:05 AM
48rat's Avatar
I messed with it last nite. just for giggles I stretched my 7# out some and hit 18# no issue and still had more to go! thanks bud. im a little fat on my afr at 10.8 so gonna lean it up a littler and see
