Blow through 5.3 boost spike help
Car is a 1947 ford coupe under 3k with me in it
Stock 5.3, cam, valve springs, hardened push rods
Vic Jr with CSU blow through carb
3800 stall th350
On3 78/75 with on3 44mm wastegate
3800 stall th350
Put the lighter spring back in and use a boost controller of some sort to hit your desired boost. You can easily make 16+lbs on a 7-8lb spring.
