smoke at cold idle
Old Aug 21, 2016 | 05:39 PM
Redbull87's Avatar
Depending on what valley cover you have and what catch can the routing differs.There are diagrams out there if you do a quick search.
Old Aug 21, 2016 | 07:22 PM
tim wellington's Avatar
Default diagram
This is the diagram that I found already. but it confuses me .Under boost the dirty pcv goes in the turbo. back in the engine ,which changes tune up right ?
Old Aug 21, 2016 | 08:00 PM
oscs's Avatar
Originally Posted by tim wellington
I hooked my pcv back to factory spot .smoking stop. but cant leave that way. because of boost . Again can some post there pcv routing with check valve and canister in stall
And this is why you don't just slap restrictors on JB turbos like so many people do. Good on you for putting in the work to find the issue.
Old Aug 22, 2016 | 06:27 AM
forcd ind's Avatar
As I said in my post, I moved from the LS 6 spot to the valve cover, and added an oil sep-i also added a ck valve, so boost doesn't blow back into the engine-simple design-I know Mighty Mouse sells a setup
By redoing the system, it thru off my tune some, since a PCV is like a vac leak, and you are adding less or more air in the engine-I run the Holley HP, so anything seems to throw it off tune, lol-the stock PCV valve allowed less air, so I had to add air at idle
Old Aug 22, 2016 | 06:41 AM
forcd ind's Avatar
This isn't a very clear pic, but I come off my 90 deg adapter, then the ck valve, oil sep, and the hose goes to the DS valve cover
I don't know who's ck valve it is, someone gave it to me
Prob a diff/better way of doing it, but this works-only thing I wasn't clear on was which way the oil sep goes, lol
Here was an interesting item I had looked at
http://mewagner.com/
Old Aug 23, 2016 | 03:10 PM
Default no smoke any more
promblem by not having pcv .i was pressurizing engine slowing down oil return now i have vent on passenger side valve cover and driver side from intake to catch can to one way check valve to pcv .NO MORE SMOKE . HOPE THIS HELP SOME ONE ELSE
Old Aug 23, 2016 | 03:21 PM
oscs's Avatar
Well done
Old Aug 24, 2016 | 11:01 PM
Redbull87's Avatar
I used to have my setup like that till i got tickets for having vents on the valve covers.Changed it up and now I have dual (mms)cans tucked behind my headlights.I daily drive my car alot in the summer and modded cars are always on blitz for **** like that to ticket you. The only thing i didnt like about venting the valve covers is the slight odor at times if i was pounding the car long enough.
Whats left on the truck now? Dyno..track?
