Which Fuel Pressure Regulator?
Old Jun 20, 2004 | 01:43 PM
PongoX11's Avatar
Default Which Fuel Pressure Regulator?
Figuring I need a fuel pressure regulator to go with my D1SC setup that is dropping pressure about 6000rpms
I have a post in fueling but getting little action and I need to have things ordered by tomorrow (monday)
Running the Racetronix setup right now with 42lb SVOs on a 99TA: S2 6.0L heads, TR224/227, D1SC@8lbs
Want to know what fuel pressure regulator to buy, from where and what else I will need to go with it
Thanks!
Old Jun 20, 2004 | 01:46 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks!
How quickly do you need the FM FPR setup?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Jun 20, 2004 | 02:20 PM
PongoX11's Avatar
By thur. would be great. Plan to go out the shop sometime this week to settle a couple other small things and would like to do this at the same time if possible--if not how soon could you put something together?
Old Jun 20, 2004 | 05:59 PM
Racetronix's Avatar
LS1TECH Sponsor
Our F-LS1 regulator system will not be out for a month or two.
Perhaps some simple -6 fittings brazed / silver soldered to the ends of your factory fuel rail and some simple Teflon line will do the job along with a universal regulator.
If you have a MAP gas torch and some basic tools it can be done.
__________________
>WEB SITE<
