LS6 vs Triple 12
Old Sep 7, 2016 | 11:01 PM
Atomatic's Avatar
Default LS6 vs Triple 12
I have a fox body running a gen IV 5.3 with 317 heads, LS6 cam, turbo 350 and 75mm/75mm turbo. I have a triple 12 cam sitting in the garage as well. Trying to decide if it's worth the time to install it vs leaving as is. Much difference in trap speed or pretty comparable? Also, much difference in lag from a roll?
Thanks.
Old Sep 7, 2016 | 11:34 PM
MY_2K_Z's Avatar
You could sell it to me for pennies and I'll run it for you lol
Old Sep 8, 2016 | 06:08 AM
94heritage's Avatar
Ls6 cam is a better cam over the stock cam up top but it lacks in the mid range. I couldnt be happier with the 3x12. It was a night and day difference over the stock lm7 cam in my 5.3. Bottom end and midrange are much stronger and it pulls like beast up top. Dyno testing showed 90hp under the curve and 50hp up top. This was on 2 psi less boost because I was running on just the spring.
Old Sep 8, 2016 | 06:15 AM
Tomhames's Avatar
Triple 12 doing some work!!
Wow- how well do they work on 5.7's or 6.0's??
Old Sep 8, 2016 | 07:28 AM
JoeNova's Avatar
Restricted User
Matt picked up 10 mph in the quarter on a stock 4.8 by doing nothing but adding a Triple 12. 10 mph in the quarter from just a cam swap on a car that's already running close to 130 is a huge jump, especially from such a small cam.
Old Sep 8, 2016 | 07:58 AM
ls1charged's Avatar
Thanks.
swap your 317's out for 5.3 heads and youll proli help with lag
Old Sep 8, 2016 | 08:08 AM
anheuserbusch08's Avatar
Get u some 243s. Those 317s dropped your compression ratio to 9.1 aka lag heaven... stock 243s will get u back to 10.1 compression
Old Sep 8, 2016 | 09:28 AM
Atomatic's Avatar
I know the cam's performance is in the right direction. Just trying to figure out if it is significant enough to bother with the swap vs trying something bigger. And I'm not complaining about the current lag, it's not bad all things considered. But I would like to know if it would be a significant difference with the triple 12.
No one has some trap speed data after this swap ?!
Thanks all for the contributions.
Old Sep 8, 2016 | 09:37 AM
svslow's Avatar
The Denmah claims to have gained, I think, 9mph over and LS9 cam when going to the Triple 12.
Old Sep 8, 2016 | 09:52 AM
JoeNova's Avatar
Restricted User
Seeing as how it's my personal favorite 4.8/5.3 boost cam, I'd swap it in place of almost anything lol.
Old Sep 8, 2016 | 10:09 AM
Atomatic's Avatar
I thought that was a from a stock 4.8/5.3 cam? I'll have to check.
Old Sep 8, 2016 | 10:29 AM
svslow's Avatar
Originally Posted by denmah
i was EXTREMELY impressed when my stock cam fairmont went 125mph then the only change i made was triple12, then 136mph! whoaaaa
Here ya go. Yes that was as stock cam.
Old Sep 8, 2016 | 10:33 AM
slowlsx's Avatar
Bigger doesn't always mean better. IMO while you do the triple 12 go with 243's , it will be a completely different car
Old Sep 8, 2016 | 01:55 PM
Forcefed86's Avatar
243's are a waste IMO. You could work your 317's or even a set of 862's and they would blow the "as cast" 243 out of the water. 243's aren't worth the $450-500 they are going for used. Great head if you can pick it up cheap, but put that same money into a set of 317's and you'll be miles ahead.
Also gotta laugh at this... 64cc to a 71cc head drops compression about .8 by my calculator. So we aren't even talking a full point. A full point of compression is only worth about 3-4% of the NA HP. So if his 5.3 made 350 NA crank HP... (which I doubt) that's like 14 crank HP difference. Figure .8 you are talking like 10 crank hp or less. That's not going to be "lag heaven". If anything it will open up the tuning window and let him get away with a little more boost.
My 8.6:1 5.3 was great. Easily got up on boost on the line and went 8's with minimal effort... 60' great as well.
Old Sep 8, 2016 | 04:08 PM
roastin240's Avatar
I like hearing this...My forged 5.3 I am assembling right now will get 317's because I have a set sitting in the spare bedroom. Havent CC'ed them but expect to be around 9:1 ish when done. In my previous experience with high boost builds, I was always running ~8.5:1 CR. Getting into the LS world, it seems like the standard is >9.5:1 with boost. I have considered dropping the coin on some 243 castings, however I cannot justify it...I feel like a drop in compression ratio wont be too bad. I am not worried about spool. I am running a 7875 BB on a 0.96 and the car weighs 3000 lbs, and doesnt have much tire. Lag would probably help the cause.
Back to the cam...I have not seen much talk about the 215/215/212 or the 218/218/212...anyone have real life results? Everything I have read says the Triple12 is fantastic.
Old Sep 8, 2016 | 05:53 PM
denmah's Avatar
Moderator
12x12x12 is hands down better
Old Sep 8, 2016 | 08:34 PM
blackfire93's Avatar
Agreed that the better of the two is the triple 12. Next best question to keep this rolling in the right direction... do you guys think the isky 218 cam is too large for this setup, or would it be another step in the right direction?
Old Sep 9, 2016 | 08:32 AM
Forcefed86's Avatar
I think there’s way too much emphasis and hype in cam selection. Trip 12 is great, I really liked mine… but a LJMS stg1 or tick stg1 would all work about as well IMO and be within 3-10whp of each other at slightly different RPM ranges I’d bet. Aftermarket cams pickup huge over the OEM stuff, but I think once you start debating cams within 10-20* of duration with similar valve events and lift… you’re splitting hairs.
The 215 and 218 grinds will move the power range up a hair over the 212. If you’re running a factory engine with a factory rev range a smaller cam usually compliments the factory parts better. If you start squeaking out more RPM with aftermarket intakes/heads/valve train etc… the larger duration stuff starts to shine. I’d grab any of the entry level cams and concentrate on the head ports with a good valve job. Should be an easy 75-125+ crank hp with a good valve job/port and cam over you’re current setup. Then double that gain for every 15-16lbs of boost you run. ( assuming your turbo system can keep up)
Old Sep 9, 2016 | 09:51 AM
svslow's Avatar
I agree with this completely. I've been doing a lot of research into cam selection lately. Going from a stock cam with crazy LSA and big negative overlap to an aftermarket cam will be a significant gain.
