4 port boost solenoid
If you plumb it like this it will make just as much boost as a 4 port.
3 ports respond faster than 4 ports too, so really there is almost no need ever for a 4 port.
At full duty the small bleed will lose negligible amounts of pressure, but it allows the system to work very easily.
With no bleed hole control can get quite tricky and will need a very very fast and well set up controller.
I was running a 3 port and no matter how much I ramped DC, i wasn't seeing gains in boost, even adding stiffer Springs in the gate put the DC waay to high for good control.
I realized, back pressure was pushing my large gate open (PW66).
I knew my turbine side wasn't optimal, but i didn't realize it would be soo excessive to push the gate open. Maybe with a stock and not turbo specific cam, this wouldn't have been as bad. Cam good, turbo bad...lol.
Now i get around 22psi @ 40% DC with a 9lb WG spring.
