added 9" spal fan to procharger shroud now how do I wire it up?
is there a specific way to wire the 9" fan up or do I just connect the fan to the factory harness and be done?
Also as for amp draw, i have a higher amperage alternator & 0-gauge wiring in the car so my voltage is higher & more stable than normal.
But anyway so run a relay in between factory harness & fan or is it needed with the electrical upgrades I have already?
your upgrades is a separate thing from the relay. UNLESS you upgraded your stock fan lines.
