TH400 vs Glide in Fox Body
We just burnt up the TH350 (had a 3200 stall) in the car and looking at going with a built Glide or TH400. We are sort of leaning towards the glide because of the lightweight of the car and we think it will be a little bit faster than the TH400 (and an easier swap for us too). But we know we would have to run quite a bit of stall. How much stall is enough to ensure that the glide isn't a dog from a dig or a slow roll? And, can you elaborate on the streetability of that much stall in a light car? Our car is by no means intended to be a street cruiser, but it will spend a lot of "fun" nights on the street.
If it helps were looking at a glide with a 1.8 planetary and we're running 3.55s out back. Thanks for any input.
And sorry for putting this in the turbo section. Figured I would get the best feedback here from people with similar setups.
after that I went to a built glide with a break and a 1.76 gearset. I'm running a 3200 ptc converter.
now with my t break and launch control I can adjust my 2 step to leave as hard as I want. my 2 step is 3300 now and it leaves at a couple pounds to 4 psi depending how long I let it build. with the glide the car is nice and calm in 1st gear and much easier to hook and get consistent 60" . my local track never preps at all so 1.50 60' is about all it will let me do on radials .
with the 350 th trans my car ran 10.54 at 10 lbs boost
the glide ran 10.52 at 10 lbs boost with all being equal
now I'm at 12.5 psi boost and it seems to like the glide even more. if the track whould hold it I can still leave much harder if it could use the power.
my car is a street car I drive it to work and 60 miles a night going to woodward in the summer time.
that being said I do think a 400th will run as good if not better if traction is not an issue. but hey are heavier . myself I like the longer more controlled 1st gear. jmho.
There's variables to say which is going to work, and comes down to several things. IE: converter/stator combo, shock design and settings (front and rear), tire that's on the car matters also.
If you street drive alot though you may consider running a taller gear and a TH400. The low first gear will let you launch the car easily with something like a 3.08 or a 2.73. That way you don't have to give up highway cruise RPM.
I even know of a guy running a 2.50 gear with a 28" tire and TH400. He uses it like a glide at the strip and shifts into 3rd for over dive on the street. He traps 140's well under 6500 in 2nd. Cruises 65ish at 2k in 3rd on the highway.
Pretty cool!
Pretty cool!
We use a bolt together PTC and have had stud problems lately.
We have a very tight stator setup in ours, and I can say it comes up pretty quick. Granted we have measures to help with staging.
