5.3 turbo lag
Compression was 160 on 2 cylinders. Cam checked out at 5* retarded installed dot to dot.
Installed my double roller with 4 degrees advanced and compression went up to 210psi on both cylinders.
I can say this tho, its alot more snapier and torqier just moving around the yard.
Cold there? Run really thick oil or something? Might try some oil thinning additive. Had a few buddies cars do this with new lifters. Quick drive with 0w-30 oil and Rislone additive fixed it. Weird yours is acting up now though.
Imma drain oil and change it may add some additive like u said to get them quiten down. I have around .80 on preload with 7.4s. What about ptv? I wouldn think so tho. Its a dished lm7 with ls9 gaskets and stock heads. Around.600 lift on cam. But i can turn it over fibe by hand no binning up. So its gotta be lifters.
I'd imagine the 5.3 doesn't have the low end n/a torque the 5.3 has and whatever converter the 6.0 could flash up the 5.3 is having trouble with.
I tuned a 4.8 in my brothers truck with 0 torque management and even that thing could smoke the tires no problem.
I checked ptv and exhaust side is good but the intake side is right at touching. So thats most likely the issue. I think im just gonna pull the cam all together and install it into the wifes tbss. And just run a stock 6.0 lq4 cam and springs on this 5.3 till i can get up the funds to get a triple12 cam and pull the converter and possibly sell it or install in the ss as well and run a ptc in the truck.
Converter was probably the whole problem.
