finally got my 9
Old Oct 9, 2016 | 04:32 PM
yenkomike's Avatar
Default finally got my 9
after fighting traction and slowly working on my launch I got my 9 second pass.
it was cool and the track had to warm up a bit so I ran a few easyier launch 10.00s with 1.6 60' times I hit it a bit harder and it stuck .
foirst 9 was
1.57
6.48@110.21
9.98 @136.26
next I tried a bit harder and as hard as the track will hold on a radial no prep track
1.50
6.40@110.53
9.90@136 mph
boost was around 14 lbs as the air was so good it went up without touching the controller.
and I found the limit of my single aem 380 pump as it whould slowly lean from mid 11 afrs to almost 12 afr at the finish line. and that is faster than I thought it whould go on e85.
time for some good shocks instead of air shocks and some srd bars and slicks . and an extra fuel pump. thanks in advance
Old Oct 9, 2016 | 05:25 PM
jasonsnova's Avatar
Nice...like the nova
Old Oct 9, 2016 | 06:40 PM
rkupon1's Avatar
Single digit club...i bet that feels good! Congrats
Old Oct 9, 2016 | 07:04 PM
yenkomike's Avatar
thanks.
ive been hanging out in the mid 10s for 2 or 3 years now.so I'm glad to be just in the 9s instead of deep in the 10s and having a blast doing it.
Old Oct 9, 2016 | 07:15 PM
Suncc49's Avatar
nice work man.. the build on your Nova is an inspiration!
Old Oct 9, 2016 | 07:23 PM
yenkomike's Avatar
https://www.facebook.com/lmm410/videos/10211206309332226/
Old Oct 9, 2016 | 07:32 PM
bigmandengo's Avatar
Congrats on getting in the 9s!
Old Oct 9, 2016 | 08:22 PM
Bad Apache's Avatar
Great job!
 Michael S. Palmer
Old Oct 9, 2016 | 08:34 PM
yenkomike's Avatar
thanks guys
had a video but it wont load. sorry.
Old Oct 9, 2016 | 08:48 PM
3 window's Avatar
GET THE VIDEO LOADED!!! Nice work Mike, good job buddy!
Old Oct 9, 2016 | 09:42 PM
slocaddy's Avatar
Congratulations mike, you said your gonna add slicks, you on streets now?
Old Oct 10, 2016 | 08:10 AM
svslow's Avatar
Which track did you go to?
Old Oct 10, 2016 | 08:59 AM
oscs's Avatar
foirst 9 was
1.57
6.48@110.21
9.98 @136.26
1.50
6.40@110.53
9.90@136 mph
Do you have any flow Info from your logs? I'd like to see where it actually dropped off.
Old Oct 10, 2016 | 05:56 PM
yenkomike's Avatar
thanks
I'm on 275 pro's now but slicks will make a difference I'm sure at my local track.
ran at lapeer dragway.
I did not log these run but next time I will. my afr has ran solid all year then this cold front hit and it changed went from 11.1 to high 11s or 12.0 but was slowly rising at the stripe. I even went in and added fuel but it didn't do much in high gear that's when I noticed my boost was up to around 14 lbs . and I have been about 12.5 to 12.75 psi all year.working on the launch.
weather I'm out of pump or not I'm going to add a second pump before I hurt it. to be honest I never thought a single 380 could go this fast in the first place on e85. so I say good job to aem there pump works good
Old Oct 10, 2016 | 09:04 PM
MY_2K_Z's Avatar
Nice job man, I love seeing these nice simple combos going so fast. Have been filling your car for a while glad it's finally getting where you want it. Again great job man.
Old Oct 11, 2016 | 08:52 AM
3 window's Avatar
How much boost were you able to leave on?
Old Oct 11, 2016 | 09:42 AM
RonSSNova's Avatar
Sweet! Nice job.
E85 is safe at 12:1, but not ideal. Get that fixed and add some boost!
My buddies run the Pros all the way down to 14psi.
someday I'll try a pair. I run the 28x9 pro bracket radials, they seem to work well.
Ron
Old Oct 11, 2016 | 10:17 AM
yenkomike's Avatar
I was leaving on a couple pounds of boost . if it leaves any harder it will spin a few cars out. when I get beyond the tree.
thanks ron I have been afraid to run less than 16.5 psi in my pro's. if I go back I will try less and see how that holds. I have noticed they don't wrinkle up very much in my video.
i'll try and post that tonight.
Old Oct 11, 2016 | 11:51 AM
3 window's Avatar
Yah, much different characteristics between a slick and a radial carcass. Leaving on ony a couple?! You get on a good track where you can get after it and you've got a 9.60 car easily IMO.
Old Oct 11, 2016 | 06:47 PM
B18B1LS1's Avatar
Nice! Shift it any higher this time out?
