finally got my 9
Old Oct 11, 2016 | 07:07 PM
yenkomike's Avatar
yeah I did. I ran it up o 6000 but I was worried about the fuel system leaning out so that is as high as I went. I think it made a difference but the better air that raised my boost a little helped to.
until I can hit it hard and hook every time it is hard to get good back to back test as every run I am trying to time the lights just right so I doesn't build to much boost and spin
I'm really wondering how these tires whould work with less air. I read keep it above 16 psi so I never went below 16.5
I know it need rear suspension work but I cant make up my mind. I think I'm going to get some srd assassin bars then get rid of the air shocks and a second fuel pump and see what it runs.
Old Oct 11, 2016 | 08:48 PM
Ratical's Avatar
Very nice times for limited traction and low boost. Glad to see you got your single digits!
I've seen some crazy times out of Cal-Trac rear suspension systems. They seem very drivable too.
Old Oct 13, 2016 | 04:04 AM
AFTER HOURS MOTORSP's Avatar
congrats
Old Oct 13, 2016 | 06:59 AM
RonSSNova's Avatar
I found that the more power I can leave on, the better the car works. I do have Caltracs and DA rear shocks.
this year I added DA front shocks but I just got the engine back in and running in time to miss the entire season.
Old Oct 13, 2016 | 07:49 AM
Guard dog's Avatar
Congrats! Now dial in that suspension.
Old Oct 13, 2016 | 08:14 AM
oscs's Avatar
I use to run my pro's at 14lbs. They will Definitely wrinkle on you. This was at 170mph.finally got my 9-photo625.jpg
Old Oct 13, 2016 | 08:31 AM
RedRocketZ28's Avatar
You don't want to run the Pro's too low. I run mine around 16.5-17 lbs. and have been a best of 1.38 60' off the footbrake on 7-8 lbs. I don't have any crazy suspension and run Comp Engineering drag shocks in the rear, ha.
Congrats on the 9 second pass.
Old Oct 13, 2016 | 08:42 AM
slow trap's Avatar
i am also amazed a single 380 pump can handle that kind of power on e85.congrats on the 9 : )
Old Oct 13, 2016 | 09:08 AM
yenkomike's Avatar
thanks . I do have a couple videos of the runs I will get on here. they are on fb from a friend but I cant copy and paste them so I will have them email them so I can post .
in the video you cant see much wrinkle at all .
Old Oct 15, 2016 | 10:05 AM
Was that at Milan?
Old Oct 15, 2016 | 07:01 PM
yenkomike's Avatar
I was lapeer.
https://www.facebook.com/lmm410/videos/10211206309332226/
