Twin turbo front mounts
lolanyway, alot of guys relocate the battery to the spare tire area.
when you start getting into forward facing turbo setups your going to have to start sacrificing things....also wont you have to relocate your fuse box too?
-brandon
https://www.google.com/search?q=forw...2wm-IL7o1UM%3A
-brandon
-brandon
http://www.bmrsuspension.com/?page=p...d=56&catid=150
Isn't mounting it off to the side the norm?
I had to un-pile a bunch of **** off my hatch to get this picture. When the car gets put away for the year it often ends up as a storage rack.
In my opinion stick with what you've got.
I think relocating the battery is necessary, both for bay appearance and weight. You'll need that 100lb offset if you go with the twins.. (assuming you use a regular battery)
I just used an Afco style battery mount in the spare tire well, modified it to fit a Taylor battery box so that the car would actually tech, but if that's no issue don't worry about the box. It made it a pain in the ***, but I'll never have to do it again, which is key. Best of luck figuring it out!
