Stock LS1 turbo ideas
Old Oct 30, 2016 | 01:08 PM
hfthe3rd's Avatar
Default Stock LS1 turbo ideas
I'm currently looking at a used T6 turbo kit or may buy a new Huron speed turbo kit. I know the basics of what to upgrade but I want a quick spoiling turbo for 1/8th mile no prep racing. I plan on doing 80lbs injectors on E85 with a bigger pump. My goals to hit around 600hp. Also the motor dynoed in at 335/356. It's a 99 Camaro 5.7 with 799 heads and a LS6 manifold that has a 3800 stall and the down fall 4.10 gears with 28" tires.
Old Oct 30, 2016 | 01:24 PM
lmt0705's Avatar
Give Casey at Huron speed a call, great products and even better customer service!
Old Oct 31, 2016 | 02:13 PM
hfthe3rd's Avatar
I might have too . I was just looking for general ideas on a turbo to run on my motor or something that may work.
Old Oct 31, 2016 | 02:42 PM
Aaron at SDPC's Avatar
I would recommend looking at an S475 or an S480. Either will work for your application, and offer room to grow.
Old Oct 31, 2016 | 07:16 PM
hfthe3rd's Avatar
Would a 96mm turbine work with 1.32 ar ? So going with a T6 set up will probably be better?
Old Oct 31, 2016 | 07:29 PM
SteenH's Avatar
Currently running an s475 83 t4 on their kit
Works great but if I had to do it again I would have just gone with the big boy 80/96 t6
Old Oct 31, 2016 | 09:47 PM
hfthe3rd's Avatar
Any problems ? How much power are you making / does the turbo spool lrettt quick ?
