Interesting cam timing observation
Old Dec 11, 2016 | 12:07 PM
RonSSNova's Avatar
Thing is...without actual testing on our own engines, there is no way to say what cam timing will work best. And that isnt really practical for most. So we just stick to what the card suggests and hopefully it will work well.
Exactly. As my engine guy has always said, with a given cam in a given engine there is one best position for it. You just have to find the sweet spot.
I'll know more in the spring when I get back to running the car.
Old Dec 11, 2016 | 01:18 PM
truckdoug's Avatar
so i know it's an impossible question but i'll ask it anyways
how much power do y'all think the average 600whp turbo guy leave on the table by throwing the cam in dot to dot?
Old Dec 11, 2016 | 01:58 PM
sbcgenII's Avatar
0 to whatever 12mph is on forcefeds car.
Old Dec 11, 2016 | 02:02 PM
stevieturbo's Avatar
It really is completely impossible.
Old Dec 11, 2016 | 02:16 PM
sbcgenII's Avatar
Negative. That was the 212/212 @ 112 JFR trip. 12 cam.
It's .
I think it's wild it made such a drastic difference with that cam. Sure would be nice to have an engine dyno lol. Pulling the Hotside and the front of the motor apart seems like a lot of work. I wish I had the time to Tune every part of my combo.
Old Dec 14, 2016 | 04:47 PM
LJMSJohn's Avatar
All that mess with the cam being in the wrong spot is why I prefer to use stock gears and IWIS chains. With comp cams cores, 99 times out of a 100 its going to land within 1 degree of where i intended for it to be.
Old Dec 14, 2016 | 04:56 PM
Forcefed86's Avatar
FWIW I installed the JFR isky cam with a factory timing set dot to dot first (without degreeing it) and it was WAY off.
Same exact cam next year I installed dot to dot on a 4.8 and it was within a degree. It was the crank keyway that was off on my 2008 LC9 5.3 near as I can tell, and had nothing to do with the cam in this instance.
