Interesting cam timing observation
I added forged internals to the L33. I let my builder assemble the short block since the clearances etc are his work. He will stand behind it.
I assembled the rest. Installed cam, heads and so forth.
When I took it apart, the once tight Cloyes chain had loosened as expected. Since it is the hex adjust setup, I obviously had to re-degree it.
Originally set it up according to the cam card. Loose chain adds a bit of retard for sure.
So I advanced it 1 degree this time around.
The only change in the short block was forged pistons/rods. Lost a smidge of compression due to the valve reliefs. Didn't really need them with my combo, but they were there none the less.
Supposedly the L33 is now 9.75:1. And supposedly the stock L33 is 10:1.
Things I never verified with actual measurements.
The heads have been milled just .005" to get them flat. But this didn't change during this latest build.
Anyway.......
On the two step before, at 3300 it made 7 psi.
Now it makes 10psi. Very easily.
This is a Martin Smallwood cam. You listening Martin?
I got this together in time to make 4 passes, I drove like crap. Short shifted every pass, and the track was toast so it spun every pass.
But was surprised that it made more boost on the two step compared to last year. With a maybe 2 degree change in actual cam timing.
Stuff I pay attention to .......in slow motion. Ha!
Ron
Anyway.......
Ron
Just saw this post, thanks!
Maybe the cam guys can comment on this?
Vaporization, homogenation & compression, as well as rod to stroke ratio & flame propagation rates, all play a role here.
Cranking compression is a good reference but not a true indicator of dynamic compression. As a variable, ideal valve curtain is a range of ideals.
How repeatable was the 3300/7psi, over how many tests ? Same conditions etc ?
And likewise the 10psi ? No other tuning changes ?
And what was the cam timing with the loose chain...vs the new cam timing +1 ? How much had the chain stretched by ?
No tuning changes at all.
I did not measure cam timing at disassembly. So my numbers are an educated guess.
I log every pass, so I'm confident in the data.
I'll know more when we get back to racing in 2017.
Forced
I never tested cranking compression prior to adding the forged internals. I did test that after the race and got very low and confusing numbers.
then discovered my compression gauge was busted.
Other than short shifting the dang thing at 6k instead of 7k, the car ran normal.
But more importantly in the real world...does it really matter ?
I've never really seen many people test stuff like this, which you'd think for such a popular chain driven setup....there would be loads of testing done that would suggest how to install a new cam/chain.
That would make me think it really does make very little difference in most cases.
Even cars with VVT etc, they need to swing the cam sometimes 20-30deg to make a measurable difference. So a couple of degrees ? Would be hard to measure any difference, if any at all. Although I guess that might change the more extreme the build, and longer duration etc the cam.
In my experience you gotta swing one way more than a degree or two to be able to give credit to the cam timing for making a change like that.
It's definitely not as simple as retard the cam for more top end and advance for more power and less top end.
Assuming you started out with the optimal cam timing and advanced the cam 2*. You will still put out roughly 99.7%. Yet 2* retarded can drop output by as much as 3%. It's also not linear, so a 4* drop may drop output 5-6%. Also have to add break-in into the equation. Chains tend to retard another 1/2* or so. So I could have been as much as 7* retarded from the card, and as much as 8-9* away from optimal timing. Obviously whatever it was robbed me of a TON of power. Went from 139 @ 21lbs to 150.8 @21lbs... No other changes. 160-195ish cranking compression.
