Need help with twin turbo selection
Old Nov 1, 2016 | 10:21 AM
LSjim's Avatar
Default Need help with twin turbo selection
how is it going i recently sold my f1a procharger and am wanting to go twin turbo or single turbo route. I have been trying to search up alot of info but cant seem to find any recommendations on turbo size for a 408 ci motor. i am looking to try and make at least 1xxxrwhp.
on another note i have been looking at this a/w intercooler and was wondering if any one has had any experiences with them.
http://www.shearerfabrications.com/sf06-02008.html
Old Nov 1, 2016 | 01:03 PM
JoeNova's Avatar
Restricted User
Forced Inductions billet S484.
Old Nov 1, 2016 | 03:18 PM
LSjim's Avatar
thanks i will look in to them!!
Old Nov 1, 2016 | 05:32 PM
stevieturbo's Avatar
Now while his goal was stated as 1xxx...
I guess a pair of 484's might be aiming towards the upper end of that ? like 1999 ?
Old Nov 1, 2016 | 06:41 PM
lmt0705's Avatar
I'm running a pair of 6766s on a 387 ci lsx, I made 1196 to the tire at 22psi with a lot left in it
Old Nov 1, 2016 | 08:08 PM
JoeNova's Avatar
Restricted User
He said twins or a single....
Old Nov 2, 2016 | 03:41 AM
Yes, but 1xxx is a pretty wide range, and main title asked twins
Old Nov 2, 2016 | 09:17 AM
LSjim's Avatar
would you run that s484 as a single on a 408?
Old Nov 2, 2016 | 09:18 AM
LSjim's Avatar
i am really just looking for bottom 1xxx i would be even happy with 900s its going to be threw a manual trans so it should be pretty easy
Old Nov 2, 2016 | 11:40 AM
JoeNova's Avatar
Restricted User
There is a mustang here that is pretty famous for doing so much with so little.
6.0 block with 4" stroke crank. Stock unported 317 heads, stock LS1 intake and throttle body. Mild cam.
Ran an S484 at like 22 lbs. Made over 1000whp and ran 7s in the quarter.
Old Nov 2, 2016 | 01:44 PM
Go for whatever will install easiest in the vehicle.
Although a pair of smaller twins would spool a bit faster than a big single and with it being a manual car, this may matter to you.
How far above/below 1k you really want to make again can have a huge bearing on sizing and whether you want to push a smaller unit hard, or larger units a little easier. Fuel used can also play a part in this too.
Old Nov 2, 2016 | 01:55 PM
breecher_7's Avatar
Twin 68/70's and make as much or as little power as you want...
Old Nov 2, 2016 | 05:21 PM
LSjim's Avatar
It will be running on e85 fueling will not be a issue
Old Nov 2, 2016 | 05:22 PM
LSjim's Avatar
do you have a suggestion on what brand to run?
Old Nov 2, 2016 | 05:27 PM
6870 as a specific size is the Precision Gen2 units...DBB only and a hefty price tag for someone only wanting 1000hp.
http://www.precisionturbo.net/Street...-CEA%C2%AE/578
As with the many other dozens of threads, a pair of BW SXE362's would spool well and easily cover his power goals and then some.
Or the slightly larger 364's with the 73mm turbine
At a push if he wanted really fast spool he could drop down to a pair of the SXE257's although they'd be working a bit harder in the 1k range.
Old Nov 2, 2016 | 05:41 PM
LSjim's Avatar
i appreciate all of the info what ar would you run with the bw sxe362's?
Old Nov 2, 2016 | 05:49 PM
See little reason not to use the 0.88, again unless you are using manifolds etc that are divided for a divided housing.
That said, I'm about to try some 0.96 housings on my 364's, although it wont be until the new year before it's going again as probably changing other stuff too. I'm only on a 383.
My 364's have the 68mm turbine wheel
I have zero backpressure issues, if anything it is great. But this is just something I wanted to try. The hole in them is surprisingly larger than the 0.88.
pics enclosed. It's amazing turbos can make so much power squeezing through the little hole inside the turbine housing ! lol
BW dont make the larger housing, it's an AGP housing
Attached Thumbnails Need help with twin turbo selection-t4-088-2-medium-.jpg   Need help with twin turbo selection-t4-096-medium-.jpg
Old Nov 3, 2016 | 10:02 AM
LSjim's Avatar
sounds good i really appreciate all the help do you know where i can buy those at?
Old Nov 3, 2016 | 10:54 AM
I got the larger housings from AGP
