Twin Turbo 33 pickup
Old Nov 12, 2016 | 11:33 AM
fisherboys's Avatar
Originally Posted by Bad Apache
X2 Forecfed is using the correct method for tuning. Please don't throw 28-36* at this thing. Nothing is more irritating than pulling down a fresh build for a rebuild/replacement. Ask me how I know. And it wasn't timing in my case. Just a leak. Love the truck and look forward to your first 5 second pass!
I'm sure I wont be putting that kind of timing in this thing, I really appreciate the tuning advice and the procedure to do so. I'd love to see a 5 something myself. No real reason for it but anybody that has raced just cant leave it alone. It's being built for power tour and to drive anywhere type of a truck , again thanks so much for all the input. Mark
Old Nov 12, 2016 | 11:39 AM
fisherboys's Avatar
The fuel you run will have a large effect.The way I tune would prove what the engine wants. Simply dial timing back to some thing ridiculously safe like 8*. Get your AFR squared away and ramp up to your desired boost level watching plugs. Then add 1-2* until you stop making noticeable gains MPH or your plugs tell you you are too hot. Make nice easy consistent launches and watch MPH ignoring ET until you get it dialed in.
Tuning that way is always safe and if the engine wants 28* then it will be clearly seen in the MPH/plugs. (chances are it won't)
The fuel is e85 and I think right now the AFR is 11.1-11.2 at WOT through out the entire run. I will try it as you say, the tracks and weather here are pretty much done for the year but there is a lot to do on this thing, Thanks again . Mark
Old Nov 14, 2016 | 07:13 PM
fisherboys's Avatar
Another newbie question, What is the limits of the stock l33 camshaft? It seems about 5400 rpm for about 3 seconds it somewhat stops pulling or just tapers off noticeably. I have a tick stage 2 turbo cam but was wanting to see what we could do with the stock cam. I know I really need to get this data logged to know what exactly is going on. It may be fuel but was wondering about the cam. Thanks Mark
Old Nov 14, 2016 | 07:50 PM
chiaj144's Avatar
I ran my stock L33 cam to 6500 every pass.
Old Nov 14, 2016 | 09:53 PM
Forcefed86's Avatar
What do you have for valve springs?
Old Nov 15, 2016 | 09:52 AM
fisherboys's Avatar
they are the ones that cam with the tick stage 2 turbo cam, btr 660s I believe
Old Nov 15, 2016 | 10:02 AM
Forcefed86's Avatar
Plenty of spring then. Sounds like something in the tune to me. Def get that data log going should pull past there easy. Do you have the auto tune enabled?
