Twin Turbo 33 pickup
What ECU/fuel management are you using? Trick is to progressively build power across the initial boost point over 1-3 seconds. If you just let boost come in hard and slap the tires it’s likely to spin. If you have a way to progressively pull/add power over time/speed you’ll get much better results. I couldn’t run more than 11lbs or so on the street with 29x12 slicks without blowing the tire off. I have a progressive boost/timing ramp now and I can run 20+lbs on the street with a 275 tire. Same power levels I run 8's with at the track.
No reason that combo can’t break into the 5’s pretty easy IMO. As mentioned, great looking truck!
I agree on high RPM race engines with large duration cams, big bores, and low back pressure race type turbo kits… you do generally run timing up where he is talking about. On SBE type builds with baby cams that will instantly break things… guaranteed. Ask your friend how many mild 5.3 turbo combos he has tuned that way.
Guys tuning SBE engines on the dyno, starting at 8* of timing. Get AFR square and then dial in the max boost. Then bump timing slowly watching power/plugs. Should see gains around 10-20whp per degree on most mild SBE setups. Many engines stop making decent gains at 11-12* on the stock cam. If you see only 3-5hp bumping to say 15*. That’s how you know the combo is done, and adding more timing is not beneficial. Back it back down to 12* and be done with it.
Tuning that way is always safe and if the engine wants 28* then it will be clearly seen in the MPH/plugs. (chances are it won't)
