what gate size with chinese billet 78/75
LQ4, 222/228 .566/.571 115+2 4l80e w/3400 stall 3.50 gears in a 9" 4 linked w/qa1 DA's all around. ~4000lb w/me. aiming for >700 wheel
I'm aiming to keep the hotside much the same as pictured here with the lil gt45 and a 44mm gate directly on the turbine housing.
should I go to a 60mm gate or will the 44mm gate suffice?
Try the 44 first since you already have it. I cant see you having any issues especially if you're keeping the gate in the same location on the new setup. Give it a shot!
