Best ARP head stud for boost?
Old Nov 29, 2016 | 02:00 PM
rivers09's Avatar
Not sure what that means, but I wasn't laughing at you. The meat between the cyls on the blocks once bored that far is pretty thin. It's likely to crack between the cyls around 1000-1300 crank hp depending on how lucky you got with your block thickness.
Man just kidding around, I do appreciate all the input and advice! I just hope I can make a little power and be reliable that's why I got good parts... I will keep you updated, you can see updates on the build @ 88 Cavalier Turbo Build in the forced induction forum, I got a lot to learn, but it's my first Ls type engine so I'm sure I will make mistakes
