Can wrong offsets for map cause erratic idle
Old Nov 29, 2016 | 08:31 AM
lmt0705's Avatar
Default Can wrong offsets for map cause erratic idle
I'm running the holley dominator with the gm 3.3 bar duramax sensor. I had to play with the values for a while to get it up and running at the start of the season and it runs pretty good except for a surging idle that I've never been able to get rid of. Could it be the map or something else? I've been playing with the IAC all summer and haven't gotten anywhere.
Old Nov 29, 2016 | 08:50 AM
hellbents10's Avatar
LS1Tech Sponsor
Ditch the damx sensor and get something that reads into vacuum well. traditional 3bar brick style or 3.3 bar ZR1 would be good. Good vacuum reading was not a design intent on a diesel sensor.
Old Nov 29, 2016 | 08:56 AM
slocaddy's Avatar
This is what I'm dealing with right now, tuner said to get a zr1 sensor as well, now just looking for the wiring info for zr1 plug
Old Nov 29, 2016 | 08:59 AM
lmt0705's Avatar
Ok, I'll just get the Holley 5 bar then
Old Nov 29, 2016 | 09:50 AM
forcd ind's Avatar
I just pick one from Holley's drop down window, makes life easier.
It doesn't take much to throw off the fuel map when you change something, I have blackened a couple sets of plugs.
If the orange ball is moving thru a few squares, try lighting up the surrounding squares, use the arrow keys +/- and see if you can force it into just a couple squares by adding/sub. fuel-I started the CL comp. over 500 RPM's, let it work on the idle and help stab. it, then I man tune below 1600
Old Nov 29, 2016 | 11:29 AM
lmt0705's Avatar
I've been playing with that forever, not getting anywhere which is why I'm wondering if it's the map sensor
Old Nov 29, 2016 | 05:05 PM
stevieturbo's Avatar
The MAP sensor reading is either right or wrong.
Simple...get a Mityvac or similar device and test it.
Although as long as it is a linear output/reading.......it doesnt really matter as you'd be tuning accordingly. But it would be silly to tune with the wrong values when it's much easier to do it with the right values.
Old Nov 29, 2016 | 06:34 PM
truckdoug's Avatar
those duramax maps are no good.
efi source has the plug n play ls1 type 3 bar and comes with the correct offsets in the paperwork. its like thirty bucks.
Old Nov 29, 2016 | 06:53 PM
lmt0705's Avatar
What are the right values for that sensor? The numbers I used in hp tuners are way different then what I had to use in the holley for some reason
Old Nov 29, 2016 | 10:52 PM
truckdoug's Avatar
linear is 305 and their stated offset is 10.33
I changed my offset to like 8.33 to get 101kPa at key on engine off
Old Nov 30, 2016 | 04:17 AM
That's only a single point.
You need to ensure it is correct everywhere.
Old Nov 30, 2016 | 07:19 AM
truckdoug's Avatar
maybe you could explain that a little bit more to me
Old Nov 30, 2016 | 11:09 AM
What's difficult to understand ?
You could have a faulty pressure gauge that reads fine at atmospheric.....but wrong everywhere else.
You could have a clock that reads fine at 12 oclock....but the mech is wonky everywhere else.
Likewise just because a map sensor readout on an ecu ( after the voltage has been converted into units you wish to see ) gives a sensible reading at atmospheric...doesnt mean it will be correct everywhere else.
As said before, if in any doubt, test it. And IMO even if you arent in any doubt....test it anyway. Always ensure critical sensors are reading correctly as you would expect before using them.
Old Nov 30, 2016 | 11:38 AM
truckdoug's Avatar
Haha no ****. I mean how would you correct it given you can only change two variables?
You get those two as close as possible and make up the rest in VE like everyone else.
Old Nov 30, 2016 | 11:47 AM
Well all such sensors are linear....so produce a straight line pressure vs voltage only 2 check points should be needed.
So as said before...test the thing and adjust whatever you need to adjust so it does read correctly.
If you cannot get it to give correct readings, then use an ecu that can as that's just ****. Not the end of the world as I've already said....but there really is no reason for any ecu not to be displaying the correct values.
Either way, it's mental to run an engine on a setup where you are not 100% sure that all sensors are reading as you would expect. That's just basic basic first steps
Old Nov 30, 2016 | 02:03 PM
truckdoug's Avatar
okay fair enough. I apologize for the bad attitude.
I thought you were hinting at a way to adjust the calibration of individual map sensors.
Old Nov 30, 2016 | 05:04 PM
You do not, cannot adjust the map sensor.
But you have a programmable ecu, you adjust the calibration until the map sensor reads correctly. Same as you would do with any sensor.
Old Nov 30, 2016 | 08:15 PM
lmt0705's Avatar
I ordered the holley one that's setup for my pcm. At least I can eliminate that
Old Dec 1, 2016 | 02:42 AM
It's a universal ecu...it should be able to be setup for any sensor.
Old Dec 1, 2016 | 01:05 PM
droksformula's Avatar
I just went through this same thing, it's totaly different order than the standard gm 3 bar, if I remmber the pins on the zr1 plug, 1 -power, 2-ground, 3-signal
