Best ls turbo Intake
Old Dec 7, 2016 | 08:26 PM
coltboostin's Avatar
Originally Posted by gtfoxy
Which is better: Chocolate milk made with Hershy's syrup or Nesquick?
for real...
Jesus
Old Dec 7, 2016 | 10:47 PM
323z's Avatar
you guy's never have the right answer... it's clearly Ovaltine...
Old Dec 7, 2016 | 10:53 PM
callys's Avatar
Why so much gear? You planning to spin 7500rpm at 130mph with converter slip?
Seems like the other parts are shooting for 150mph+
Old Dec 9, 2016 | 09:29 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Shaun's Custom Alloy does some pretty badass intakes... my personal favorites bar none.
Old Dec 10, 2016 | 08:51 PM
truckdoug's Avatar
Originally Posted by MY_2K_Z
Nesquik for sure
u str8 trippin
hershey syrup always
Old Dec 10, 2016 | 09:28 PM
DavidBoren's Avatar
Holy F'ing Shaun's Custom Alloy intakes, Dr Whigham! Those things are legit. I had never seen those before. They sure are nice. Definitely not necessary for anything still using a factory crankshaft, though.
Old Dec 11, 2016 | 01:14 PM
mOtOrHeAd MiKe's Avatar
From: Saskatchewan, Canada - where arguing "DA" is for the slow and weak...
I really like the plenum volume in this unit: https://ls1tech.com/forums/generatio...y-results.html
Old Dec 11, 2016 | 08:17 PM
truckdoug's Avatar
looks like it's sonic welded upper to the lower like the dorman ls6 intake
someone should see if it holds boost
aka not me
Old Dec 11, 2016 | 10:29 PM
aka not me
Nope, it is a 3-piece design and can be taken apart. Probably holds as well as any FAST intake.
Old Dec 12, 2016 | 07:45 AM
truckdoug's Avatar
put some boost to and let me know how it goes
Old Dec 12, 2016 | 09:49 AM
http://www.performancetrucks.net/for...-piece-441542/
Maybe at a future date.
I run a Holley Mid-rise on my Procharged TBSS... works just fine.
Old Dec 12, 2016 | 09:55 AM
  #32
JoeNova's Avatar
Restricted User
aka not me
A guy on YB blew apart a Dorman LS6 intake at 15 PSI.
Old Dec 12, 2016 | 11:40 AM
  #33
truckdoug's Avatar
Yeah he tossed it after a bunch of boost leaks
Old Dec 12, 2016 | 04:14 PM
  #34
Super-glue it?
Old Dec 12, 2016 | 11:10 PM
  #35
truckdoug's Avatar
hell if it's actual nylon like the stock one, a plastic welder would be best. but thats a lot of work for probably marginal gains.
Old Dec 13, 2016 | 12:03 AM
  #36
RonSSNova's Avatar
I chose the Edelbrock Pro Flow simply because I didn't get a truck intake with my L33.
Martin Smallwood designed me a cam that works in conjunction with the runner length of the Edelbrock intake. I also run the small 78mm stock TB.
Combo works well.
Like everything, a guy could try multiple combinations to find the best part. Myself I don't have the time or the funds to do that.
Ron
