Water meth spray ring on compressor outlet
Old Dec 9, 2016 | 12:53 PM
3 window's Avatar
If I were to run a 10 gph nozzle after the turbo, how much pre?
Old Dec 9, 2016 | 04:56 PM
etijsma's Avatar
To those of you that spray pre turbo can you pot a pic of how you did it?
Old Dec 9, 2016 | 06:37 PM
JoeNova's Avatar
Restricted User
Its usually done the EXACT same way it is done after the turbo.
Drill a hole in the piping, thread in the nozzle.
If you're talking about those of us that do it without any type of tube or filter on the turbo inlet, then its easiest to say that we dont lol.
Old Dec 10, 2016 | 08:45 AM
Forcefed86's Avatar
Depends what you are spraying and the type of boost your running. If your intercooled very little. I spray 2gph pre and 7gph post.
Ideally you want it spraying at the center of the nut as close as possible. I have 45* fitting angling the nozzle at the compressor nut.
Idea is you don't want it to wet down the piping walls.
Old Dec 11, 2016 | 10:23 PM
customblackbird's Avatar
Pre and post centri supercharger meth injection here. Spraying 30% and now 50%. But I also run a FMiC.
