Connecting rod orientation
Old Dec 15, 2016 | 08:33 PM
moekluse's Avatar
Default Connecting rod orientation
Hi guys, I posted this and didn't get much replies, hopefully someone here can help. Sorry if this is a dumb question
I dont know which orientation the connecting rod should face, let's say the piston arrow is facing up, which side of rod faces upwards?
I appreciate any imput, thanks
Old Dec 15, 2016 | 08:50 PM
sschoeffler's Avatar
You have it right in the first picture
squarles67's Avatar
The side with the chamfer goes toward the counterweight of the crankshaft, it's there to clear the radius of the journal
Old Dec 15, 2016 | 08:56 PM
Senna's Avatar
Bearing tangs go away from cam or close to pan rail.
Looks like the same rods and pistons I just dropped off to get balanced.
Old Dec 15, 2016 | 09:10 PM
moekluse's Avatar
So side by side it will look like this right? This is with wider chamfer facing outwards
Old Dec 15, 2016 | 09:12 PM
squarles67's Avatar
Yes, wide chamfer goes on the outside
Old Dec 15, 2016 | 09:19 PM
moekluse's Avatar
Thank you all very much, I'm getting them balanced then I can get to the fun part!
Old Dec 16, 2016 | 06:18 AM
forcd ind's Avatar
As said, chamfer goes to the counter weight-also ck your bearings, there may be an upper and lower half, same reason as chamfer on the rod
Old Dec 16, 2016 | 07:52 AM
moekluse's Avatar
will check when I get home, thanks for the heads up
