Engine Building Simulation Software
Old Dec 16, 2016 | 08:52 PM
squid's Avatar
Default Engine Building Simulation Software
What is good, especially for centrifugals?
Obviously, there are a number of "price classes," such as Free, $100, $200, $500, and more.
I want to work out cam timing with a centrifugal.
Thanks
Tom
PS. Pretty much not interested in anything which doesn't at least use the Method of Characteristics.
Old Dec 16, 2016 | 11:19 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Thanks
Tom
Given the real world knowledge base available, I would ignore any software-based predictions . Ask yourself if your goals are really that much different than what someone has already done.
Old Dec 17, 2016 | 02:42 AM
SethU's Avatar
Certainly could take that route if the end goal is the end goal.
Doesn't do much in the way of education, understanding, and curing curiosity though.
Monkey see monkey do... or monkey learn monkey do. Neither right or wrong.
I'm curious too. Haven't used one in years. What's being used now-a-days?
Old Dec 17, 2016 | 04:57 AM
stevieturbo's Avatar
Thanks
Tom
If you are needing to ask here....then could you really provide such software with all the relevant data in the first place for it to even attempt to simulate a result ?
And any such software worth using, will cost thousands of dollars.
If you want to work out cam timing properly and optimally for your engine...spend that money on dyno time and test it.
Otherwise stick to what the cam supplier/grinder recommends....as they will have done the simulations/guesswork already ( you hope )
Old Dec 17, 2016 | 05:51 AM
alocker's Avatar
I would tend to agree with this statement unless you just have tons of money and time laying around, then go for it.
Old Dec 18, 2016 | 05:12 PM
squid's Avatar
I'm looking for a preliminary design phase tool for an engine development program.
Old Dec 18, 2016 | 05:29 PM
pantera_efi's Avatar
Default EAP Engine Model
I ALWAYS do this work using EAP-Pro from Performance Trends., EVERY engine rebuild.
When one "port flows" the head AND uses a Cam Doctor/Lobe File for the input specifications, the results WILL be within 5%.
Another reason is I then have a "setup sheet" for future reports.
Just ask, I will do this for FREE.
Lance
Old Dec 18, 2016 | 07:40 PM
truckdoug's Avatar
thats pretty neat. thats the kinda stuff i wish i had more time for.
Old Dec 19, 2016 | 01:52 PM
93camaro_zzz's Avatar
This could do everything you wanted to do. But I'm quite certain you don't want to pay for it.
http://www.ansys.com/products/Fluids/ANSYS-Forte
Old Dec 19, 2016 | 01:58 PM
roastin240's Avatar
I use Ricardo WAVE for 1-D engine simulations. For in-cylinder CFD for our engine designs I use CONVERGE....I forget what WAVE costs but we spend like 5-10 grand a year on it if I recall and CONVERGE is 40 grand for a 1 year license. Obviously not justified for your average motorsports enthusiast.
But I agree 100%. Basically everyone is monkey see monkey do. I must understand all the nitty gritty details...but being an engineer by trade, all day every day, I cannot accept any less. I am not down to just copy someone else's build who was successful. I will estimate airflow vs. pressure and plot a trace through a compressor map to see where I am at throughout the entire engine operating range, etc. rather than just buying a turbo everyone says is awesome (just 1 example). And take it "too far" as most would say. But I dont do this just to be fast, I do this to exercise my skillset and learn more. Sounds like your after the same thing.
Old Dec 19, 2016 | 02:16 PM
Thanks, to those who use science.
I have used EAP for more that twenty years, thus a great data base.
I KNOW one item, for sure, that finds a problem that has never been in error.
That "item" is an error in engine design found by a model of the engine.
ALL can agree ?
I was supplied with Ricardo WAVE used for testing with my "camless" Ford Ranger 2300.
My customer was FEV.
Lance
Old Dec 28, 2018 | 10:28 PM
squid's Avatar
Yes, I have made no progress in 2 years. One year I spent, literally all my time, reroofing my house - I'd like to forget that.
However, I have been looking at the affordable stuff with EAP Enterprise @ $750 sounding interesting, but disappointing when they specifically warn NOT to use the software to match turbos. (sad emoji)
One criteria for a good program would be the ability to see that the move to high efficiency turbos resulted in back pressure less than boost and cam designs becoming like normally aspirated.
If the software can make that distinction, then that is a pretty good package. EAPent has compressor maps but NO turbine maps. I do not believe they can predict turbo backpressure. But they appear to be able to predict turbine shaft HP.
I'm a FEM jock from Pratt & Whitney and had ran a transient thermal analysis of a split compressor case to predict the change in compressor blade tip clearance... that ran for 17 days on the biggest/fastest RS6000 at UTRC. So know about all this 3D stuff.
But just a good 1D code using Method of Characteristics for wave action would be just fine. 1D finite difference is not that hard.
Consider that Matlab was $25k to purchase and now you can get it for $150. There are now free CFD codes out there but it doesn't look like GT Power, Ricardo, etc. are feeling any heat. Yet. Some day, some sharp tuner kids from MIT will write something in Python that will eat everyone's lunch... (must check Python libraries now...)
EDIT: ...check this out. A white paper with all the equations for the various components of the engine: VALIDATION OF A 0D/1D COMPUTATIONAL CODE FOR THE DESIGN OF SEVERAL KIND OF INTERNAL COMBUSTION ENGINES
Old Dec 29, 2018 | 02:22 AM
gsteele's Avatar
^^^ You sure that is a good link? 2:20 AM and it is not working for me.
Old Dec 29, 2018 | 08:04 AM
squid's Avatar
My Bad...
Try the link again, the original one I posted was to the pdf file that was created on my PC. I corrected the link to the URL that opens the pdf. (Doing a search on the title would work too.)
Old Mar 17, 2021 | 08:38 PM
squid's Avatar
Just thought I'd touch base to see if there's anything new out: simulation software that can predict turbo backpressure.
Trying to understand how a moderate HP TT build (800-1000hp) results in 30 mpg in a 500 cu in engine which is a far greater mpg than when it was OE NA .
I would speculate that this 30 mph state could be achieved NA if the sole objective.
Old Mar 17, 2021 | 11:44 PM
LetsTurboSomething's Avatar
Gas mileage is much more complex than cam power. High mph on larger engines is usually the result of leaning them out and running a compression and squishband clearance that allows for 15-16:1 AFR's in cruise.
30mph in a 500ci engine is the result of gearing, fueling, weight, aerodynamics plays maybe the largest part here. It's so much more than just the engine let alone the internals of the engine. Transmission advancement is huge for efficiency.
But really for seeing what a cam will do...they don't simulate it on software from what I've heard and seen of the major cam cutters. It's all trial and error and they literally just keep cutting cams and changing things until they dial one in that's just right. The cam they stick in a box and sell you is the result of probably hundreds of test cams in the scrap bin.
Old Mar 20, 2021 | 03:52 AM
gametech's Avatar
The last 5 years of your life should hopefully explain my first answer to you. If not, good luck on wasting the rest of your life chasing computer theories that some random internet user turned into a software model.
